  3. Groups >
problem on asp.net
Question asked by prabhat kumar in #Coffee Room on Jan 18, 2010
prabhat kumar
prabhat kumar · Jan 18, 2010
Rank D2 - MASTER
hi everyone,presently i m working in asp.net.i want to retrive data like move
first last add jst like in a form,i have already done gridview list view and form view,if here anybody have done this type of coding then say me is it possible?
if yes then how? Posted in: #Coffee Room
funmonster
funmonster · Jan 21, 2010
Rank E1 - BEGINNER
prabhat kumar
if yes then how?
Dude! I'm familiar with ASP.NET, but I didn't understand what you say. If you can elaborate I may help you.
funmonster
funmonster · Jan 27, 2010
Rank E1 - BEGINNER
Hurst
When I write code in ASP.NET to access the database...what can I do to avoid thisproblem. to the database server else there is a problem with username and password if the connection.
Make sure the database connection is open till you your query is completely executed, As in the following example:
public partial class Login : System.Web.UI.Page
SqlConnection con = new SqlConnection(@"Data Source=.\SQLEXPRESS;AttachDbFilename=|DataDirectory|\.mdf;Integrated Security=True;User Instance=True");
protected void Button1_Click(object sender, EventArgs e)
String qry = "select username,password from registration where username=@username and password=@password";
SqlCommand cmd = new SqlCommand(qry, con);
cmd.Parameters.Add("@username", SqlDbType.VarChar, 40).Value = UserName.Text;
cmd.Parameters.Add("@password", SqlDbType.VarChar, 40).Value = Password.Text;
con.Open();
SqlDataReader dr;
dr = cmd.ExecuteReader();
if (dr.Read())
Session["uname"] = UserName.Text; //UserName is the ID of the text box field
Response.Redirect("SuccessfulLogin.aspx"); //Direct the control to user profile
else
Response.Redirect("Loginfailure.aspx"); //Direct the control to login failure page
con.Close();
prabhat kumar
prabhat kumar · Jan 29, 2010
Rank D2 - MASTER
thanks every one i got my solution...
funmonster
funmonster · Jan 30, 2010
Rank E1 - BEGINNER
prabhat kumar
Please choose best solution or post it so that it may help some one in future..
Click to Log-In or Sign-Up
