ORMADAS-ONLINE/OFFLINE RESOURCE MANAGEMENT AND DIRECTORY ACCESS SERVICES
Project Abstract / Summary : · This Project is used to elaborate the predetermined technique (cloud techniques) but with higher monitoring and processing capabilities.
· This project is used for remote system monitoring and resources access.
· By using this software a normal computer can be enhanced to do the work of server.
· Through this software Admin can give the directory access both online and offline.
· Admin can set privileges to different users for directory access and data access.
· Admin at runtime can monitor the list of active user who is logged in, access the directory and data, up-request and down-request of user.
· Client can use the different database driver in a single panel to access various DBMS, ORDBMS, BIG DATA FRAMEWORK and GOOGLE DATA STORE to store their data.
· Client can only store their data and can access their data with the Admin permission.
· This software can be used in both Linux and window platform.
· It is just like a cloud data store but with big data capabilities, with runtime monitoring and access management.
· This application can be used to store any kind of data like spatial data, relational data, image data, vector data, video data, spreadsheet data and so on.(and of any size).
· It provides the data compression capability.
· Using this software user can store runtime data as well.
· There are two kinds of mode-OFFLINE and ONLINE mode.
· OFFLINE mode is just like a window server AD LDS Structure where an application run at client side and user can access the directory to whom which user has access and user can also access the required database or framework to access data and user data in directory will be in compressed mode.
· In ONLINE mode there is a unique login created to access the online resources and user can access the database storage facilities (but user can have permission of SQL Injection in ONLINE mode only if Admin will allow).User can only store their data in a specific directory.
· User can make their own folder and manage their grant directory.
· User can compress their data.
· User can retrieve or download their data.
· A user profile is managed for each user.
Why did you choose to work on this project topic : Because there are limited tools or software like this and unique feature that have been added in this software like multiple database support,both online and offline monitoring of clients, online/offline directory access services,database adapter selection on the basis of type and size of data make this software different from the other tools or software.This software has multi-platform support.
Project Category : CS / IT / Networking
Institute/College Name: HMR Institute of Technology and Management
City: New Delhi
State: Delhi
City: New Delhi
State: Delhi
Quote:
The spacecraft in question is called LISA Pathfinder, and in common with jewellery, it will contain a significant quantity of precious metal when it blasts off from ESA’s spaceport...
Quote:
Experts answer your questions on the emerging field of 3D bioprinting.
While 3D printing becomes more established within the manufacturing sector, one of its most exciting uses, to create...
If you weren’t paying close attention to the installation process of the latest uTorrent chances are you allowed an additional program to be installed on your computer that uses a...
Project Abstract / Summary : VISUAL INFORMATION SYSTEM INTEGRATING OUR NEIGHBORHOODS
OBJECTIVE :
The main aim of this project is to design a wearable system (shoes) to detect and avoid...
Project Abstract / Summary : In Indian construction industry Ready Mix Concrete (RMC) are popular because of its
advantage such as better quality control, better workmanship and speed in construction...
