MOSFET/Solid state relay connection to drive high current solenoid.
Hi CEngz,
Facing a new challenge in making "Electronic Fuel Injection System". Using a PWM circuit, we generate a square wave form signal (5V peak to peak). This output signal is fed to MOSFET/Solid State Relays (for switching ON/OFF) to drive a solenoid operating at high current (20A) & High voltage (24V) from 2 car batteries connected in series. The ON/OFF takes place @ the rate on 25 times per second. Can anyone suggest a part/item or a complete circuit diagram along with the connections for the above requirement. The PWM circuit can be seen at "https://www.dprg.org/tutorials/2005-11a/index.html"
Any help would be appreciated.
Thank You.
Thank You.
RRITESHHello,
as per your schematic & question you are taking 5V supply, increase it upto 9V (not more than 15V b'coz mosfet at gate voltage of 15V will burn out), you are taking o/p from 7 pin then feed this to gate of mosfet ( take IRF 3205) #-Link-Snipped-#
try this this may help......
try with common source.. -
d_vipulHey Cean,
use SCR instead which has higher power current capacities............
Regards,
Vipul -
RRITESHHello,
SCR are the old tech. using MOSFET is fine, after mosfet. it comes IGBT ( insulated gate bipolar transistor) its currrent capabilities is more than 400amps....................
Robot scans and solves Rubik's Cube in around 10 seconds
Read more: Robot scans and solves Rubik's Cube in around 10 seconds | News | The Engineer
YeY! CrazyEngineers came again with an Awesome and Awesome interview with one of our CE – Stars. He is CEan – xheavenlyx, a Crazy Electronics and Instrumentation Engineer who has...
HI,.... Currently im building a robot to participate in robowar. I need your suggestion,....
speed of motor
torque
which metal should i use to cover the robot
If anyone knows,...
Here is a short description of how DHCP works.
DHCP stands for dynamic host configuration protocol. It's a protocol that lets network admin to automate the assignment of IP addresses...
An International Conference on Control, Communication and Power Engineering is going to be conducted during Nov 07-08, 2011, in Pune, India.
The event is organized by Association of Computer Electronics...
