@sai008-vB0PL1 • May 9, 2009
haii .......be specific abt what kind of help u need is it related to programming or hardware or both ...post it here and I will help u out and tell which microcontroller are u using okk....
@harshad-ukH5ww • May 10, 2009
Its easy to interface microcontroller with stepper motor.. just you have to control port pin of Controller and need a Driver circuit for the stepper motor nothing else
3atefdata OP
@3atefdata-JcOsJD • May 10, 2009
Thanks for reply
I want both of hardware & software
I am not specified in kinds of microcontroller
In details
I have five photocopier trays and I want to control the motors of feed for every tray in sequence to be like collator (but with 5 bins) see this link
<a href="https://www.youtube.com/watch?v=UApJdaJT1kQ&feature=PlayList&p=6F74BA0918139AD2&playnext=1&playnext_from=PL&index=1" target="_blank" rel="nofollow noopener noreferrer">- YouTube</a>
after this video I think you will know what I want -
See there is no readymade circuit availble i can give you some Reference designs from that you have to modified according to your application.
Software part.. Same thing man -
3atefdata OP
@3atefdata-JcOsJD • Jun 2, 2009
Hi
Now I've got the mechanical Hardware, 4 Paper draw units
Every Unit has:
1- lift motor (24 Volt)
2-electromagnetic clutch (24 Volt)
3-Draw Coil (24 Volt)
4-Brake Coil (24 Volt)
5-tray sensor (with 3 terminals)
6-Level sensor (with 3 terminals)
7-draw coil sensor (with 3 terminals)
8-Pass sensor (with 3 terminals)
Note: The sensors are like beam or Optical that feel any thing cut the beam or make it still continuos without any cut.
and I want to control that 8 elements per every unit ,
8*4 = 32 element
I' not expert but I have an Imagine for that in this flow chart
![[IMG]](proxy.php?image=http%3A%2F%2Frapidshare.com%2Ffiles%2F240247346%2Fflow_chart.bmp.html&hash=ecb588c7083d504bfbce07432e99a310)
3atefdata OP
This flow chart
