  3. Groups >
L&T placement papers and selection process
Question asked by Reya in #Campus Placements on Aug 22, 2011
Reya
Reya · Aug 22, 2011
Rank A3 - PRO
Aptitude questions asked in L&T:
Q1. Cost of an item is x. It's value increases by p% and decreases by p% Now the new value is 1 rupee, what is the actual value ?
Ans.(1000)/(1000-p*p).
Q2. A right circular cylinder and a cone are there. Base radius of cone is equal to radius of cylinder. What is the ratio of height to slant side if their volume are the same?
Q3. Distance between two poles is 50 meters. A train goes by 48 at a speed of kmph. In one minute how many poles will be crossed by the train ?
Q4. A pole seen from a certain distance at an angle of 15 degrees and 100 meters ahead by 30 degrees. What is the height of pole ?
Q5. For 15 people--each has to pay Rs.20.For 20 people--each has to pay Rs.18. For 40 people--how much has each to pay ?
Q6. If p=2q then q=r*r , if p-odd then q is even, whether r is even or odd ?
a) first condition is sufficient
b) second condition is sufficient
c) both are sufficient
d) both are not sufficient
Q7. If A occurs which of the following must occurs
I. F & G
II. E and H
III. D
(a) I only
(b) II only
(c) III only
(d) I, II, III
(e) I, II (or) II, III but not both
Ans. (e)
Q8. If B occurs which must occur
(a) D
(b) D and G
(c) G and H
(d) F and G
(e) J
Ans. (a)
Q9. If J occurs which must have occurred
(a) E
(b) either B or C
(c) both E F
(d) B
(e) both B and C
Ans. (b)
Technical:
Q1. What is the ideal op-amp CMRR ?
Ans. infinity.
Q2.For a 13-bit DAC the MSB resistance is 2kohms. What is the LSB resistance ?
Ans. 2kohms * 2 12
Q3. The layer in the OST model handles terminal emulation
a) session
b) application
c) presentation
d) transport
Ans. (b)
Q4. Long int size is
a) 4 bytes
b) 2 bytes
c) compiler dependent
d) 8 bytes
Ans. (c)
Q5. Find the output of
x=2,y=6,z=6
x=y=z;
printf("%d",x);
Q6. FTP is carried out in ___________ layer ?
7. in diesel engine the comp. ratio is ______ then expansion ratio(more,equal,less,...)
8 . carbon help in the improving __ of steel(ductility,malliability,hardness,machinability)
9. pig iron is manufacture in --------blast farness
10. what is the effect of increase arc lenght in building
11. m 62 indicates ------ 6mm outer diameter & 2 mm pitch
12. what rapture failure.
13 . 6 cylinders in a row , n0. of crancks = 1
14. If in a steam power plant vacuum in condenser reduces what is the effect
15. pressure in industrial pneumatic lines -------5 to 10 bar
16. effect of low temp. ( -20 degree ) on carbon steel .
17.method of hardening of machine guides ways
18. method of joining plastic by welding
19. safe method of loading on a cantilever
a) UDL b) center point load c) triangular load having zero at center
20. BMD for UDL in cantilever
Ans. parabolic
source: Careers > Jobs | Placements > Placement papers - www.btechguru.com Posted in: #Campus Placements
Reya
Reya · Aug 22, 2011
Rank A3 - PRO
Selection process:
1.written test
2.Group discussion
3.Interview(HR AND Technical)
Written test consists of three sections -Quans,Analytica,verbal.All the three sections has 30 questions carries 30 marks.
Reya
Reya · Sep 7, 2011
Rank A3 - PRO
L&T Placement Paper 2011
WRITTEN TEST consists of 90 questions each questions carries one mark.
1.Aptitude
2.Reasoning
3.English
ashi874
ashi874 · Jul 4, 2017
Rank E2 - BEGINNER
hey,
You can buy books online from SaleYourBookS
They have large variety of books specially for btech students at low price. I will deinitely recommend you to buy books from there.
Click to Log-In or Sign-Up
