LG Showcases The World’s Largest (88-inch) & Highest Resolution (8K) OLED Display
LG Electronics takes a lot of pride in its display sub-division as they churn out the best displays available in the market. LG Display has out done itself by bringing out the worldâs largest and highest resolution display. LG Display is going to showcase its new display at CES 2018 which is an 88inch panel with 8K resolution. Now you might be wondering that we already have larger displays in the market, what is so special about this display? You see unlike the current 4K resolution panels which are LED backlit, LCD panels the new display from LG is an OLED one.
This new OLED display from LG has a resolution of 7680 x 4320 pixels which takes the cumulative pixel count to nearly 33 million pixels. This means the new panel has 16 times more pixels than your home TV which is probably a Full HD one. Even if you own an expensive 4K or UHD TV, the new display from LG puts it to shame as it has four times as many pixels. Now making an 88-inch 8K OLED display was needed because LG had a few thoughts regarding the existing display technology which is LCDs.
LCDs are usually non-emissive which means they require backlight units. When the resolution of displays is increased something called aperture ratio comes into play. Aperture ratio is described as the ratio of the area that can pass through when a region is not covered by black matrix and wiring portion of the pixel. Normally when electronics manufacturers go for higher resolution they try to reduce the pixel size but this in turn affects the aperture ratio and this reduces the brightness of the display. In order to compensate for the reduced brightness manufacturers have to increase the performance of the backlighting which increases power consumption. OLED panels can easily overcome this issue as OLEDs are self-emissive and require much less power than backlit LCD panels.
Since OLEDs do not require backlight units they are also much slimmer and lighter than their LCD counterparts. OLED panels also offer deeper blacks, wider viewing angles and brighter colours as compared to LCD panels which make them the ideal platform to view 8K resolution content. Now only if 8K content was that much easier to find.
A recent study unveils that your phone's password is scientifically guessable, as a team at Nanyang Technological University has found a way to unlock the phone by reading its sensor...
Chinese smartphone and PC giant Lenovo has added the new K320t smartphone to its K-series lineup. The phone has been aimed at the budget segment and is being sold at...
Supermassive Black Holes have always been the area of interest for researchers and cosmologists. The year 2017 has witnessed many new research publications which have proved their importance. Recently one...
For those that still religiously read books:
The 100 best nonfiction books of all time: the full list
China is gearing up for the launch of Chang'e 4, a set of two unmanned lunar missions which are being seen as the most ambitious and complex moon missions yet...
