  3. Groups >
is baseline wandering associated with emg and eeg also??
Question asked by Shirani Vijai in #Brainy Puzzles #Career Help #Campus Placements on Apr 2, 2020
Shirani Vijai
Shirani Vijai · Apr 2, 2020
Rank E2 - BEGINNER
since eeg also has a frequency of .5Hz
Posted in: #Brainy Puzzles #Career Help #Campus Placements
Ramani Aswath
Ramani Aswath · Apr 2, 2020
Rank A1 - PRO
Baseline wander artifacts are common in various biomedical signals. Various methods are used to remove them.
https://scholar.google.co.in/scholar?hl=en&as_sdt=0%2C5&q=baseline+wandering+in+eeg&btnG=
Shirani Vijai
Rank E2 - BEGINNER
thanks for the answer. what about emg signals? do they also have baseline wandering? if yes please give reason
Ramani Aswath
Rank A1 - PRO
All animal or human biomedical signals are small amplitude ones from sources with high and variable impedance even during the course of one test. The animal or human subject is poorly grounded. The vagaries of the line power supply adds another dimension.
I was a volunteer for some brain research project recently, which required my gamma waves to be monitored with different stimuli. Some sixty electrodes were attached to my scalp, head immobilised and recording started with various stimuli appearing on the screen in front. Nothing was recorded after more than two hours of frustrating tests.
Finally the issue was traced to some floor polishing equipment working two or three floors above the test room. The electrical noise conducted back into the supply voltage by the highly variable load of the machines completely wiped out the small gamma wave signals.
We had to repeat this test on a holiday when the machines were idle.
One of the major issues with developing such signal processing is to develop appropriate algorithms for such artefact removal.
EMG should be no exception.
Shirani Vijai
Rank E2 - BEGINNER
Thank you!!! I am sure about  baseline wandering interference eeg ecg emg and also thanks again for the explanation
Shirani Vijai
Shirani Vijai · Apr 21, 2020
Rank E2 - BEGINNER
can anyone explain lms algorithm? and also why is it better thn using weiner optimal filter? please explain lms algorithm
Click to Log-In or Sign-Up
