  3. Groups >
Innovative clamping\fixture technology (instead vacuum, magnet, ice).
Question asked by Yulian Yosef in #Coffee Room on Nov 27, 2009
Yulian Yosef
Yulian Yosef · Nov 27, 2009
Rank E1 - BEGINNER
Innovative clamping technology named OPTO-ACT (OPTO Adhesive Clamping Technology) developed by MTS-RND from Israel for fixture complex geometries and ultra high precision of produced parts (you can search OPTO-ACT or MTS-RND to learn more about the technology).
- Strain-free clamping process.
- Cycle time (clamp and release) of a few seconds.
- Functioning temperature between -50 to 1500 ºC.
- Non-sensitive to vibrations heat or liquids.
- No damage to part on release process.
- No limit to size of the clamped work piece.
- Ability to clamp most geometries and materials.
- Final tensile strength of 450 kg/cm².
- Highest precision that exists today on market!
Yulian Yosef.
MTS-RND Posted in: #Coffee Room
gohm
gohm · Nov 27, 2009
Rank A3 - PRO
If you wish to advertise you need to contact the site administrator
Yulian Yosef
Yulian Yosef · Nov 28, 2009
Rank E1 - BEGINNER
OK I will do so.
Yulian Yosef
Yulian Yosef · Dec 1, 2009
Rank E1 - BEGINNER
If you like to ask any question about the OPTO-ACT you welcome.
Mechanist2010
Mechanist2010 · Dec 9, 2009
Rank E1 - BEGINNER
Hi,
Can you explain how does it work?
zaki_whiz03
zaki_whiz03 · Dec 10, 2009
Rank D2 - MASTER
Yulian Yosef
how can innovate clamlping technology replace vaccum, magnet, ice?
what are the various machines that use vaccum magnet and ice for fixing or clamping operations.
Yulian Yosef
Yulian Yosef · Dec 17, 2009
Rank E1 - BEGINNER
zaki_whiz03
Hello Zaki,
The OPTO-ACT (OPTO Adhesive Clamping Technology) actually have the same "roll" as vacuum, magnet or ice clamping strain free clamping process, during machining.
The machines that use vacuum, magnet, and ice clamping are: milling machines, turning machines, grinding machines, and ect.
Yulian Yosef.
MTS-RND
Mechanist2010
Mechanist2010 · Dec 23, 2009
Rank E1 - BEGINNER
Yulian Yosef
Hello Zaki,
Yulian Yosef.
MTS-RND
Please, can you answer me also?
Yulian Yosef
Yulian Yosef · Jan 7, 2010
Rank E1 - BEGINNER
Mechanist2010
The process is based on a sensitive adhesive to heat, in a few seconds you can
obtain tensile strength of 80 Kg/cm² (light source 8 watt/ cm²) part release by a
special mechanical system in one second. The remains of the adhesive are
removed by a chemical.
Yulian Yosef.
MTS RND
saggi1991
saggi1991 · Jan 16, 2010
Rank E1 - BEGINNER
But that clamping will be permanent. Unlike magnet or vaccum.
Yulian Yosef
Yulian Yosef · Jan 26, 2010
Rank E1 - BEGINNER
saggi1991
Hello Saggi,
It will not be permanent, there is a mechanism built in the OPTO-ACT system that release the part without any damage.
If you like to see milling action please press on the attached link:
YouTube - OPTO-ACT Milling action, chip size 11mm (deep), AL-6061 tool Dia. 3/8"
Yulian Yosef
MTS RND
Click to Log-In or Sign-Up
