CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@safwan • 31 Aug, 2009
I am learning visual studio 2008 . I want to join my project with sql server 2008(Specifically not any other like oracle or mysql ) . Firstly I want to create database name "Library " but when i open SQl server Management studio it opens but it opens one more small windows it says connect to server. but I run it on my home pc as I want to study so when I connecet it with my pc and I open database file which already written by some one else it shows me Message
"Unhandled exception has occred in a component in your application. If you click countinue .the application will ignore error and attempt to countinue .
Object reference not set to an instance of an object." 😒
well, this was when I try to run new script. 😒
But I want to create new database and make tables and records of my own on SQL server can any one give me steps or links which help me.
@sookie • 31 Aug, 2009
Hi safwan,
Assuming your setup and installation process was done successfully. Please check if you are looking for following links :
SQL Server Express Edition For Beginners
SQL Server Tutorial
Web Development with SQL Server 2008 Express How To Guides
For Installation -> Sql Server 2008 Express Edition Installation Guide
Hope can be of any help.
Thanks !
SQL Server Tutorial
Thanks !
@safwan • 24 Sep, 2009
well, still I get problems Why I dont get SQL command line in SQL srver 2008 express like ORacle 10g. I have already installed it .when I start Microsoft Sqlserver Management studio and try to connect it its ask me server name i dont run any server but I just type my pc name still its shows error in connection and big message.
@safwan • 25 Sep, 2009
I searched on MSDN but still its not appropriate on it .
@Mahesh Dahale • 25 Sep, 2009
Connecting to server
There is an authentication in authentication there are 2 types
1) SQL server authentication
2) Windows authentication
This is set to windows authentication
There are 2 tabs on the connect to server dialog box : the login tab and the Connection Properties tab
To view the conn. Properties tab click the Option button. Use the connection properties tab to input authentication credentials and server name
if your PC name is Home then Server name will be HOME\SQLEXPRESS
I think it will help you And also
For Installation Guide https://www.packtpub.com/article/microsoft-sql-server-2008-installation-made-easy
Otherwise you also Try This:-
To connect to your SQL 2008 database using SQL Server Management Studio, follow the steps listed below:
Open SQL Server Management Studio, the "Connect to Server" window will open. Select/enter the following:
- Server Type: Database Engine
- Server Name: [The SQL server name found in Control panal]
- Authentication: SQL Server Authentication
- Login: [SQL 2008 Login name]
- Password: [SQL 2008 Password]
6.7k views
@Ankita Katdare · Nov 29, 2013
BSNL or Bharat Sanchar Nigam Limited has tied up with Pantel Technologies Private Limited to launch three new smartphones in India called Penta Smart PS501, PS650 and the one with...
5.5k views
@Mayur Pathak · Sep 11, 2008
Alright these are very simple and actually very stupid riddles. But lets see how soon can you crack them.
Six glasses are in a row. The first three are full...
5.5k views
@fantasy_craze · Jul 13, 2013
Hi,
My rank is 118 ( A+B+C). Can I get any tuition fee waiver???total fee is around 80000/-can anyone tell me ?
3.1k views
@qaisarpk1 · Nov 4, 2008
i need soltion manual of electronic communication system by kenedy.
plz tell me where from i can download it?
8.2k views
@divyankdhumas · Jan 12, 2010
suggest me topic for paper presentation,related to my branch i.e. petrochemical,topic can be on various modern techniques for extraction of petrochemicals from crude.
3.9k views
