  3. Groups >
How to convert .bat files into .txt files?
Question asked by parihar888 in #Programming #Linux on Jan 17, 2008
parihar888
parihar888 路 Jan 17, 2008
Rank E1 - BEGINNER
Hi聽,
How can we extract .bat files to .txt file 馃槙.
Posted in: #Programming #Linux
parihar888
Rank E1 - BEGINNER
Let me know
HI ,
we can easily create batch files just saving the text in notepad with .bat xtension , but how can we get .bat file to .txt file???
LORD_EC
LORD_EC 路 Jan 17, 2008
Rank C3 - EXPERT
Re: Let me know
Right Click on the .Bat file and then use "open with" dialog to open it with Notepad.
Prasad Ajinkya
Prasad Ajinkya 路 Jan 21, 2008
Rank B1 - LEADER
rename the .bat extension to .txt? Will that not work??
viiper
viiper 路 Mar 21, 2008
Rank E1 - BEGINNER
Select 'Open with' option from the right click context menu and then choose "Choose Program". Select notepad from the list and then you can save the file in .txt form
friendster7
friendster7 路 Mar 22, 2008
Rank C1 - EXPERT
u can convert the .bat file into .txt file..by
selecting the .bat file right click>>properties>>openwith change to Notepad..
Sai s
Sai s 路 Dec 3, 2018
Rank E1 - BEGINNER
you can easily convert .bat to .txt by simply right clicking on the .bat file and select edit.From there copy the whole code and paste it into a new notepad and delete .bat file.
Yes!you are done........
Vinay Mishra
Vinay Mishra 路 Jan 13, 2020
Rank C1 - EXPERT
You can do it by several methods.
1) Simply change the extension of file from .bat to .txt (if it ask for permission with a warning, allow it).
2) Copy the whole content from .bat file and paste it in a new .txt file.
3) There are some platforms available on internet where you can just drop your .bat file and it will get converted into any extension you want. For example: The world's largest computer file extension library with detailed explanation of each file type with links to associated software programs.
Teja Reddy
Teja Reddy 路 Jan 16, 2020
Rank D1 - MASTER
Batch files(.bat) are already text files you don't have to convert them manually if u wish to open u can directly see using text editor but if want to convert then it's very simple just rename file from .bat to .txt extension that's it.
Click to Log-In or Sign-Up
