  3. Groups >
How does phase advancer improve power factor
Question asked by Ronald Asega in #Electrical on Aug 5, 2019
Ronald  Asega
Ronald Asega · Aug 5, 2019
Rank E2 - BEGINNER
Posted in: #Electrical
Kavya Burramolla
Kavya Burramolla · Dec 23, 2019
Rank C1 - EXPERT
Generally any induction motor consists of two major elements called stator and rotor. Also with the fact that stator winding draws current which lags the supply voltage by 90 degrees. This is the main reason for the low power factor in the inductor motor.
In order to increase the power factor, phase advancer is used as a.c exciter which is mounted on the shaft of the induction motor and connected to the rotor to provide ampere turns to the stator winding that provides exciting current, hence leading the current by 90 degrees. Resulting in the improved power factor.
Satish Gupta
Satish Gupta · Feb 21, 2020
Rank E1 - BEGINNER
Here is complete article.. please fallow the link
Power factor correction with Phase advancer
Click to Log-In or Sign-Up
