  3. Groups >
How can we calculate the required torque to move a big object by means of gear assembly?
Question asked by Vinay Mishra in #Mechanical #Automobiles on Feb 2, 2020
Vinay Mishra
Vinay Mishra · Feb 2, 2020
Rank B2 - LEADER
I need to know the required torque of a motor to move a vehicle of about 100-150 Kg. The vehicle is equipped with gear assembly and required to run at 20 to 25 Km/h.
One of my friends suggested me to read about tractive torque. But it was little confusing.Only one thing that I understood is the formula-
Tractive Torque =  Tractive Force x mean wheel radius
Can anyone help me out of this?
Posted in: #Mechanical #Automobiles
Noothan Kumar
Noothan Kumar · Feb 22, 2020
Rank C1 - EXPERT
Hi,
Rolling Friction
The torque required [Nm] at the wheels is Maximum force[N] x radius of the wheel{m]
T(wheel) = F x r
This has to be converted to the torque required at the machine side, which is a ratio. Ignoring all losses, power in = power out, but one can generally allow for a loss of about 2% therefore,
T(motor) x w(motor) = T(wheel) x w(wheel) where T is in Nm and w (angular velocity) is measured in radians per second.
To include gearbox efficiency of 98% this becomes
0.98 T(motor) x w(motor) = T(wheel) x w(wheel) (you will need more torque at the motor side to overcome the inefficiencies)
To convert rpm to radians per second: w = rpm x 2Pi / 60.
Thank You. Happy Concepting.
Click to Log-In or Sign-Up
