  3. Groups >
Help to get o.s selection menu during startup .
Question asked by faizaan in #Startups & Business on Oct 20, 2009
faizaan
faizaan · Oct 20, 2009
Rank D1 - MASTER
Hi ceans,
I was having two o.s installed windows 7 & windows xp sp3
at that time i was getting o.s selection menu at start time.
But now i have formatted my windows 7 partition and reinstalled it now
i am not getting any o.s selection menu at start up and directly windows 7
starts so can any one suggest how to get that o.s selection menu back.
waiting for reply. Posted in: #Startups & Business
itchap
itchap · Oct 20, 2009
Rank C1 - EXPERT
Please provide some more information like in which drive Windows 7 is installed and in which the Xp SP3 is installed.
mahesh_dahale
mahesh_dahale · Oct 20, 2009
Rank B2 - LEADER
Try this
when you cannot boot to Windows XP after installing Windows 7
1. Open an command prompt.
2. Type the following to create a boot loader for Windows XP.
bcdedit /create {ntldr} /d "Windows XP"
3. Type the following to set the device to where Windows XP is installed. I used D: in this example. Replace it with the drive letter of your XP installation.
bcdedit /set {ntldr} device partition=D:
4. Type the following to set the path.
bcdedit /set {ntldr} path \ntldr
5. Type the following to add this boot loader to the boot up screen.
bcdedit /displayorder {ntldr} /addlast
6. Reboot the computer.
I hope this will help you ?
faizaan
Rank D1 - MASTER
itchap
Hi itchap,
Windows 7 is installed in c drive & xp sp3 is installed in f drive .
faizaan
faizaan · Oct 21, 2009
Rank D1 - MASTER
mahesh_dahale
Try this
Hi mahesh, Thankyou
I did above mentioned steps
Now i am getting o.s selection menu at startup but when i select windows xp sp3 i am not able to log in and it gives error .I am able to log in in windows 7.I think there is some problem in path for sp3 i.e /ntldr because there is no such file in my sp3 drive.
I used easybcd software and it is giving information about boot manager as below.
Windows Boot Manager
identifier {9dea862c-5cdd-4e70-acc1-f32b344d4795}
device partition=C:
description Windows Boot Manager
locale en-US
inherit {7ea2e1ac-2e61-4728-aaa3-896d9d0a9f0e}
default {ad3c2927-bdd3-11de-ad76-e81e83152ab9}
resumeobject {ad3c2926-bdd3-11de-ad76-e81e83152ab9}
displayorder {ad3c2927-bdd3-11de-ad76-e81e83152ab9}
{466f5a88-0af2-4f76-9038-095b170dc21c}
toolsdisplayorder {b2721d73-1db4-4c62-bf78-c548a880142d}
timeout 30
Windows Boot Loader
identifier {ad3c2927-bdd3-11de-ad76-e81e83152ab9}
device partition=C:
path \Windows\system32\winload.exe
description Windows 7
locale en-US
inherit {6efb52bf-1766-41db-a6b3-0ee5eff72bd7}
recoverysequence {ad3c2928-bdd3-11de-ad76-e81e83152ab9}
recoveryenabled Yes
osdevice partition=C:
systemroot \Windows
nx OptIn
Windows Legacy OS Loader
identifier {466f5a88-0af2-4f76-9038-095b170dc21c}
device partition=F:
path \ntldr
description windows xp sp3
pls help ..waiting for reply .
faizaan
faizaan · Oct 24, 2009
Rank D1 - MASTER
please reply.
yadavundertaker mohit
yadavundertaker mohit · Oct 24, 2009
Rank B2 - LEADER
if any of your friend has same motherboard as you then from his C drive copy the file ntldr and paste it in your drive where xp sp3 is installed.
To err is human, but the one who rectifies is a champion.
my blog
searchofmydestiny.blogspot.com/
Rank B2 - LEADER
i also had the same problem but i just paste the ntldr file . I have Intel G-31/33 motherboard if you have the same then i will send it to you ....
my blog
in search of my destiny
faizaan
Rank D1 - MASTER
hi yadavundertaker,
I am having msi-k9n2gmfih MB but as none of my friend has same MB so i took copy of ntldr from my friend having intel MB after pasting that file in my sp3 drive i tried to reboot so when i tried to login sp3 it restarts pc and before i pasted that ntldr file it used to give error regarding ntldr.
Is there any other way to solve this problem ?
Rank B2 - LEADER
if you don't find the same mother board ntldr file then there is only option to reinstall your window xp sp3 .......i will try to find your file .if i get it then i will send it to you..Ask other CEan if any one have the same motherboard as you have.....
my blog
Rank B2 - LEADER
check this link it is not opening in my pc https://www.google.co.in/url?sa=t&so...r4W1AQ&usg=AFQjCNFVdj_S6Iatplupntn8fCZqHCoE_g
my blog
Click to Log-In or Sign-Up
