GATE 2015 - Unable to upload Photograph/Signature even when it is as per specification
Question asked by Andrew John in #Coffee Room on Oct 4, 2014
Andrew John 路 Oct 4, 2014
Rank E1 - BEGINNER
Hi there,
I'm in a dilemma here 😔
I've read the specifications for uploading the files and made the photo, sign and certificate. Still the error shows up in the application process.
Can anyone who has experienced this already, help me with it..
I have the
Photo at 480x640 - 61.6kB
Signature at 420x120 - 39.6kB
PDF certificate at 178kB
Am I wrong anywher? Please help.
Thanks for your time. Posted in: #Coffee Room
I have the
Abhishek Rawal 路 Oct 4, 2014
Rank A2 - PRO
First of all, Signature pixel res should be between 80x280 to 160x560. Yours doesn't fit the criteria.
Secondly, decrease the resolution (remember min is 240x320) upto the extent when the image size reduces <= 50 kB
Andrew John 路 Oct 5, 2014
Rank E1 - BEGINNER
I meant the signature pixels are
Width - 420 px
Height - 120 px
Is it wrong?
Width - 420 px
Height - 120 px
Is it wrong?
Abhishek Rawal 路 Oct 5, 2014
Rank A2 - PRO
Width cannot exceed 160p (min = 80p) & Height cannot exceed 560p (min = 280p)Andrew JohnI meant the signature pixels are
Width - 420 px
Height - 120 px
Is it wrong?
As you're using 420x120p, you're failing in matching both criteria of W & H.
Andrew John 路 Oct 6, 2014
Rank E1 - BEGINNER
Ok. I get it. So the signature needs to be in portrait mode? I felt it was landscape from the GATE sample signatures.
Rank E1 - BEGINNER
SOLVED!
The problem was not with the dimensions or resolution.
I tried it in another browser (Firefox) with the same pics and it worked out PERFECT.
Don't know what was wrong in Chrome.
Thanks Abhishek for your patient replies.
Abhishek Rawal 路 Oct 6, 2014
Rank A2 - PRO
That's weird, because if we look at criteria in GATE brochure & resolution you've used for signature; it's just unacceptable.Andrew JohnSOLVED!
Anyways, we're glad that you were able to upload it. 馃榿
cubancigar11 路 Oct 13, 2014
Rank E1 - BEGINNER
So, are you saying that the image should be in portrait mode? Please clarify because as it is your statement is very confusing.Abhishek RawalThat's weird, because if we look at criteria in GATE brochure & resolution you've used for signature; it's just unacceptable.
Abhishek Rawal 路 Oct 13, 2014
Rank A2 - PRO
cubancigar11So, are you saying that the image should be in portrait mode? Please clarify because as it is your statement is very confusing.
Rank E1 - BEGINNER
I just submitted my signature. The image does NOT need to be in portrait mode.
Here are the steps:
1. Scan the image in 200 dpi - this generated a file in TIFF format for me.
2. Open it in IrfanView
3. If you want to align the box correctly, use 'Edit -> Show fixed grid' and 'Image -> Custom/Fine rotation'
5. Select the 7cmx2cm box and use 'Edit -> Crop selection (Cut out)'
4. Use 'Image -> Resize/Resample', unselect 'Preserve Aspect Ratio (proportional)', set new size as Width: 560, Height: 165. Leave DPI as 200.
5. 'File -> Save As', save JPEG, quality 100.
6. Try uploading several times if it doesn't work the first time. Try logging-in again and then uploading instead of trying in the save form again and again.
HTH
Here are the steps:
HTH
Sumit Bhadra 路 Oct 14, 2014
Rank E2 - BEGINNER
when i am trying to upload the pdf file for Certificate from Principal/HOD its saying that "Upload failed! File uploaded is not as per specification"...so plz help me I am in great trouble now....plz anyone kindly help me...in what shuld the criteria for uploading the pdf file....
cubancigar11 路 Oct 14, 2014
Rank E1 - BEGINNER
Keep trying... :/ That is how it worked for me...
deepsea123 路 Oct 14, 2014
Rank E2 - BEGINNER
Hi
I have been trying to submit my application for gate 2015 since yesterday.... am still not able to submit as the choice of exam city 2 and city 3 drop down list is not coming. so am not able to select any city. Have uploaded photo, sign, and certificate. Please help.
Gaurav Tak 路 Oct 15, 2014
Rank E2 - BEGINNER
Yes, the select exam city 2 and 3 drop down list is not working.
Just open the site on a mobile browser and it will definitely work.. 馃榾
aditya aman 路 Sep 20, 2015
Rank E2 - BEGINNER
hi...my signature is not completely displayed in application form...why?
Ankita Katdare 路 Sep 21, 2015
Rank A1 - PRO
@aditya aman
When uploading image of the signature -
- The maximum pixel resolution for the image is 800 x 300.
- The minimum pixel resolution for the image is 400 x 150.
microgate 路 Sep 23, 2015
Rank E2 - BEGINNER
I am facing the problem while uploading the signature.My image is width 150p and height 514 p with size 15 kb.Can anyone help?
Ankita Katdare 路 Sep 23, 2015
Rank A1 - PRO
It should be the other way round.microgateI am facing the problem while uploading the signature.My image is width 150p and height 514 p with size 15 kb.Can anyone help?
For GATE Signature -
400 px = width
150 px = height
Allen2015 路 Sep 23, 2015
Rank E1 - BEGINNER
n
Rank E1 - BEGINNER
Uploading the signature is giving me serious headache. It took half of my day trying to figure it out. I must have created more than 20 pictures, with different resolutions. In the form, it says maximum pixel resolution 160 x 560 and minimum pixel resolution 80 x 280. The width has to be between 80 and 160 and the height has to be between 280 and 560.
The lady above has written: For GATE Signature -
400 px = width
150 px = height.
How is that?
Anyway, for safe side I created images of all the possible resolutions. In JPG format, file size between 12-13kb.
160 X 560
560 X160
80 X160
160 X 80
85 X 170
170 X 80 etc
None are working, when I upload, it says "Signature is not as per the given Resolution/Aspect ratio specification!"
I created these images using picassa, paint and freeonlinephotoeditor.
Could anyone here please point out what I am doing wrong. I would be very grateful to the genius who can fix this problem. Oh, I tried different web browser as well, still not working.
400 px = width
150 px = height.
How is that?
160 X 560
560 X160
80 X160
160 X 80
85 X 170
170 X 80 etc
Rank E2 - BEGINNER
Thank You
Swapnil Narvekar 路 Sep 24, 2015
Rank E2 - BEGINNER
Hi Allen,
maximum pixel resolution 160 x 560 means - Your image should be of width - 560 and height - 160. it is other way round.I faced the same problem.I was able to resolve by keeping it with this dimension.Your image should be - Width : 560 and Height : 160
Swapnil Suman 路 Sep 24, 2015
Rank D1 - MASTER
Draw a box 7cm X 2cm on a white sheet of paper. Sign within the box in appropriate size so that signature is clear enough. Upload on a computer system. Crop the photo to the borfers of the box.If possible, try to crop the border line of the box. Go to MS Paint. Find for options to edit attributes of the photo (like resize, rotate etc.). Then make the size to 7cm X 2cm. Save (Save As) it. Upload in the form. I hope it works. If the size of photo is not within the limits, you may compress picture by using Microsoft Office Picture Manager which is present with almost any MS Office Suite installed on your system.Allen2015Uploading the signature is giving me serious headache. It took half of my day trying to figure it out. I must have created more than 20 pictures, with different resolutions. In the form, it says maximum pixel resolution 160 x 560 and minimum pixel resolution 80 x 280. The width has to be between 80 and 160 and the height has to be between 280 and 560.
400 px = width
150 px = height.
How is that?
160 X 560
560 X160
80 X160
160 X 80
85 X 170
170 X 80 etc
Thenaruvi 路 Sep 24, 2015
Rank E1 - BEGINNER
I am unable to upload my certificate from principal. It's saying laiku "upload a vadil eligibility certificate of PDF format". Pls help me out
Rank E1 - BEGINNER
I am unable to upload my certificate from principal. It's saying like "upload a valid eligibility certificate of PDF format" again and again. Pls help me out
Rank E2 - BEGINNER
could you please tell me the size of the file which you are uploading. it must be between 10 kb and 300 kb
Arghyadeep Sarkar 路 Sep 24, 2015
Rank D3 - MASTER
i am not able to upload my signature although i have resized it to 80x280 pixels. my file size is 15.3kb. 馃様
Rank E1 - BEGINNER
72kb, PDF format onlySwapnil Narvekarcould you please tell me the size of the file which you are uploading. it must be between 10 kb and 300 kb
Allen2015 路 Sep 24, 2015
Rank E1 - BEGINNER
Thank you guys for the response. After wasting half of my day trying to upload the signature, I asked my sister's friend how she uploaded the signature. I asked her to send the signature she uploaded.
She had uploaded the signature of 90 X 27. Hmmm... I thought, if it worked for her, it should work for me, Voila, it did. Guys, if you are still unable to upload signature, please create the image with 90 width and 27 height. Problem solved.
Ankita Katdare 路 Sep 24, 2015
Rank A1 - PRO
@Allen2015 That's really helpful. Thanks for the tip. I hope others find it out here and get helped.
Murugesan Eswaran 路 Sep 28, 2015
Rank E2 - BEGINNER
Hi All,
I was also facing same issue. Finally got it. No need round the world, simple step is there in the GATE site itself. Go to FAQ section, click Signature related FAQ and download the sample.
Once done Open it in paint and paste your signature that you are having in the system. Don't change sample signature's dimension instead change your signature's dimension if needed.
FAQ link : https://www.gate.iisc.ernet.in/?page_id=775
Thank you.
Thank you.
Rank E2 - BEGINNER
Sorted Out!!
Please go to FAQ section where you will be able to see sample signature. Save & Open the same in Paint and paste your signature, save and upload. That's it.
FAQ Link : https://www.gate.iisc.ernet.in/?page_id=775
PARAS J PATEL 路 Sep 30, 2015
Rank E2 - BEGINNER
guys juz set width 280 px nd height 80 px in paint...it'll work
Rank E2 - BEGINNER
open your scanned "sign" in "paint" then select it,set width 280px, height 80 px(deselect maintain aspect ratio)
Raj Anil 路 Oct 3, 2015
Rank E1 - BEGINNER
how to adjust maximum pixel resolution 160*560 and minimum pixel resolution 80*280?
Atharva Singh 路 Oct 7, 2020
Rank E2 - BEGINNER
Go to 袨斜褉邪斜芯褌泻邪 JPEG 褎芯褌芯谐褉邪褎懈泄 芯薪谢邪泄薪 - IMG online聽
Choose the image
Set the pixels as width 560 and height 160
Choose - with stretching or narrowing ( in the aspect ratio tab)
Set the dpi as 200
Convert it and upload it.
