Electric generator issue (7,5 KW)
Hello out there
I need the help of an electric CE for an crazy selfmade electric genarator. The motor is a 2 zyl. 12 HP diesel engine and the genarator is brazilian with 7,5 KW capacity. Everything works fine, I can handle home lights, TV's and all smaller stuff and it works with the 60 Hz. When it comes to connect my fridge or a aircondition the voltage falls to almost 0 but the capacity should be enough to handle those things. I changed the brushes from the original carbon ones to carbon-copper and it got a little better but still doesn't generate what it should.
Do anyone out there have an idea what's the issue that drives me crazy?
Thanks from Ecuador
Thanks from Ecuador
maheshkrishnanHay for Refrigrator and for A/C they will take intial pulll of current, so dripping will cause.
Try to stabilize that first -
sauravgoswamibuddy,u need some kinda pull-up device which will generate enough energy to cater to your AC or refigerator.As loading occurs when you switch your AC or refigerator!!
phoneworksYou need a automatic voltage regulator. Sometimes if you carry a heavy load with some generators, their voltage and frequency tend to change. Hence you need something that can regulate/keep the voltage and the frequency to normal
i am a Mechanical Engineering student and i have to do a minor project so help in choosing a title for the project and give some information about the topic
TOP B-Schools in INDIA
1. IIM - Ahmedabad
2. IIM - Bangalore
3. IIM - Calcutta
4. MDI - Gurgaon
5. S.P.Jain Inst - Mumbai
6. IIFT - New Delhi...
Okay,
The time has come that we start collecting the worst ads on the Televisions all over the world.
Here's the Youngistan ad which I think adds no value to...
hey crazy dudes out there..theres a new guy in the block..
Hello every one
can any one help to give me CDMA reference tollbox in MATLAB programm
please
