CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@lovejeet • 31 Dec, 2010 • 3 likes
hey, sorry to ask, but wat is the difference between electrical and electronics?? a basic question though, but most of the people have their different views......... so guys.........
@freak16 • 01 Jan, 2011 Electrical is working with high voltages and conductors insulators though with power electronics electrical deal with semiconductors also but the main domain in electrical is power apparatus power systems and power electronics with all electronics things
Electonics is all about semiconductors . ics and working with low voltages ..
@lovejeet • 01 Jan, 2011 means the main difference is the working voltage only???????
@freak16 • 01 Jan, 2011 Yes it is the most basic difference..by the best of my knowledge
@NDL • 03 Jan, 2011 In simple way the things which needs to be plug in to work or which needs the direct electricity to work that is electrical like T.V, Iron, Fan etc.
And electronics are those which can work on cells or battery like your cell phone, transistor etc...
@Arp • 04 Jan, 2011 i think
in electronics we generally deal in lower value of current (mA or so) and voltages(in V)
in electrical we deal with higher value(kA and KV).
i suppose not sure...
@sankaran • 18 Sep, 2011 • 1 like i think electronics is a moment of electrons in a semiconductors or circuit..
electrical is refer to power.
@Ramani Aswath • 18 Sep, 2011 In the early days of IIT Madras, there were only heavy current and light current streams. The former was electrical and the latter was electronics.
@Reya • 18 Sep, 2011 • 1 like @sankaran: If you dont know the meaning of electronics,why dont you learn in wikipedia or some other sites.
Electrons in semiconductor at a particular point in time is called electronics?
Wow! what a definition!
@anuj kumar singh • 21 Sep, 2011 the diffrence between electrical & electronics is that in electrical high range of voltage & current are used as compare to electronics... and in electrical insulator , capacitor are used but in electronics semiconductor is used
@Anthony Jarmie • 11 Jan, 2012 Hi,
I know electronics deals with low power and electrical with high power, but I want to know more technical difference.
Does anyone have an idea please help me?
Thanks and regards
Anthony Jarmie
@aarthivg • 12 Jan, 2012
Anthony Jarmie
Hi,
Thanks and regards
Anthony Jarmie
In simple words
"electrical" means flow of electrons.
"electronics" means study of electrons.
@naga lakshmi • 14 Jan, 2012 The study of conductors is Electrical. The study of semicoductors is Electonics
@DHINESH BABU.G • 20 Jan, 2012 The current flows through the conductor is electrical and the current flows through the semi-conductors is electronics.
@Mr.Don • 21 Jan, 2012 • 1 like Electronics is anything having to do with semiconductors, silicon or germanium, eg circuits involving diodes, tranistors etc(these regulate currents for better efficiency).While Electrical means generating electricity(major) and controlling it where no semiconductors are involved . eg motors , generators, and circuits involving capacitors, inductors.
Hope the below link will provide more information to you 😀
https://www.crazyengineers.com/commu...nd-electronics-engineering.49453/#post-191609
@Arnav Joshi • 24 Jan, 2012 • 1 like
aarthivg
In simple words
I would like to add something to this , electronics means 'controlled' flow of electrons.
@Sparker • 30 Jan, 2012 • 1 like but some how I would liketo add extra point,Electronics is something which uses electrical signal to transmitt datas or information but Electrical issomethong we used to transmitt power or energy to do something.
So basically electonics is main concern with Datas or Information meanwhile Electrical take care of power,
@Bionic • 05 Feb, 2012 • 1 like Electronic engineering is a branch of engineering which deals with the study of current flowing at a low voltage in certain kind of materials mainly semi conductors such as silicon while electrical deals with the study of current flowing in a very high voltage of many thousand volts in certain materials such as copper these materials are mainly good conductors...
Areas of specialization in electrical engineering include
*Power devices
=electrical machines
=power electronic
=electromagnetic field
*Power system
*Automatic control systems
while electronic engineering include
*Electronic circuit
*communications
*computer technology
*control system
though both are not too different, they share many things in common.
@lalit.joshi • 05 Feb, 2012
Anthony Jarmie
Hi,
Thanks and regards
Anthony Jarmie
well... anthony i am new in CE, i have jst seen your question now and i think i can assure you about electronics and electrical. simply electronics deals with flow of current and its application and uses low power whereas electrical deals with generation, transmission, utilisation of current. as well as earlier electrical equipments are regulated manually but now with the help of electronics devices like robotss,😀
@Bionic • 05 Feb, 2012 Electronic engineering is a branch of engineering which deals with the study of current flowing at a low voltage in certain kind of materials mainly semi conductors such as silicon while electrical deals with the study of current flowing in a very high voltage of many thousand volts in certain materials such as copper these materials are mainly good conductors...
*Power devices
=power electronic
*Power system
*Electronic circuit
*communications
*control system
@lovejeet • 05 Feb, 2012
Bionic
*Power devices
=power electronic
*Power system
*Electronic circuit
*communications
*control system
quite satisfying answer. but then, how can one decide that the study of how much current belong to which category, ie. electrical and electronics?? i mean, what is the distinguishing limit of the current value for both the cases?
lovejeet
well its not fix but lies within a certain range of values for electronics lets say its current of operation lies mainly within the range of 100uA to 250uA and below.
For electrical its range may lie within the range of say 33MW and above
In electronic mainly it depends on the type of semiconductor used.
Bionic
33 MW and above for electrical?? you know what it means?? and MW isn't the unit used for measuring current too.
so devices with 1 A to 12 A will come in which category then??
@Bionic • 06 Feb, 2012 well
lovejeet
Well we can still include that range within electrical, I was just trying to give an estimate of what kind of high current and voltage electrical uses.
@FerdousMostofa • 08 May, 2012
lovejeet
(I am not that much confident but with hel of wiki.ans) elctrical i.e things or when dealings comes related to devices those are run or use electricity on the other hand electronics refers to (as the name at a glance refers to electrons) dealing with semiconductor devices like MOSFET, Transistors as there are question of movement of electrons or hole i.e proton(theoretically)
@lovejeet • 08 May, 2012 • 1 like
FerdousMostofa
aren't they alike? electricity means flow of electrons only. get a deeper study on the topic.
@Ramani Aswath • 09 May, 2012 • 2 likes When IIT, Madras, irst strted, electrical engineering and electronics were differentiated only as Light Current and Heavy Current engineering. AS I had mentioned in another thread quite often discussions are more on semantics than logic. There is nothing much to argue about except based on the individual's own meaning of the terms. No conclusion can be reached. Best to agree to disagree.
@lovejeet • 09 May, 2012 ohhh........isn't it ambiguous then, sir? maybe not since there may not have been any need to clearly distinguishing both terms.
lovejeet
You are probably right.With the kind of controls used in modern distribution and the use of heavy current electronic equipment for many areas, the distinction is blurring.
@Bionic • 21 May, 2012 there is nothing to be confused about the two fields. Electronic is a special field of specialization of electronics electronics was formerly a branch of electrical engineering, but it became so wide and complex that it has to be made a separate field of specialty.
@Kaustubh Katdare • 21 May, 2012 Yeah right; that's the reason why most of the textbooks in both courses are usually the same. I however admit that I'd have loved to study few of the topics in depth that are usually taught to electronics engineers.
@zaveri • 22 May, 2012 electricals
deals with conductors and insulators like RESISTORS, INDUCTORS AND CAPACITORS.
electronics
deals with semiconductors like DIODES and TRANSISTORS.
@NAVATHE SACHIN • 27 May, 2012 electronics deals with low voltages upto 15 volts where electrical deals with high voltages .
@KZ 259 • 27 May, 2012 electronic engineers usually focus on consumer goods. electric engineers focus on electric motors, radar and navigation systems, communications systems, and power generation equipment. this source can be found at:
https://www.bls.gov/ooh/architecture-and-engineering/electrical-and-electronics-engineers.htm
@Ankita Katdare • 27 May, 2012 I think this is a very old thread and it is time to close this.
18.1k views
@Kaustubh Katdare · Jan 10, 2015
Everybody knows that Microsoft's working on a brand new web browser. Codenamed 'Spartan', the browser will be integrated with upcoming Windows 10 operating system. It's no wonder that Microsoft will...
3.8k views
@Manish Goyal · Nov 21, 2009
Today there was my internal viva of dbms in which i was asked 3 questions that i would like to share with you 1 what is partial key? 2 what...
6.3k views
@ravindra25 · Aug 15, 2009
tell me the some minor project ideas on mechanical engg.
10.3k views
@Kaustubh Katdare · Aug 27, 2012
Every year, a large number of engineering students flock CrazyEngineers Forum looking for tips and tricks on how to prepare for campus recruitments. I thought of compiling an article to...
7.7k views
@Ankita Katdare · Feb 25, 2015
More and more people nowadays discuss how intelligence is overrated. An old Forbes article (that has been really popular in recent times) shares a research done by Carnegie Institute of...
5k views
