  3. Groups >
Detecting a beep sound by speaker in vb.net
Question asked by medeepak in #Coffee Room on Oct 26, 2010
medeepak
medeepak · Oct 26, 2010
Rank D1 - MASTER
hi
i need to make an app which detects if the speaker has given out beep
sound or not
can you help in me in doing it
could not get much help on searching the net
regards
deepak Posted in: #Coffee Room
Manish Goyal
Manish Goyal · Oct 31, 2010
Rank A2 - PRO
it seems you want make some voice application ,in that case voice xml may help you
i am not sure whether you can use it with vb.net or not ,but voice xml is commonly used for these purpose
BCA_GIRL
BCA_GIRL · Nov 1, 2010
Rank C2 - EXPERT
You should read this :
Beginning ASP.NET Using VB.NET
I think it will help u..........good luck!!
medeepak
medeepak · Nov 4, 2010
Rank D1 - MASTER
hi guys
thanks for your help
i got it done using some dlls
but i have a new problem
if i run an infinite loop in c#.net it not show the form when i debug (trial run) it
what may be the reason
themask
themask · Nov 25, 2010
Rank D1 - MASTER
can you post your code. so that other can also get out of it.
Click to Log-In or Sign-Up
