Data Structure/Algorithm Challenger II
We have a doubly-linked-list with number of nodes unknown.
Sometimes, while working with the list, it somehow gets corrupted. The corrupt node is pointing to some previous node instead of next node. So a circle is created in the list.
Test for the existence of circle (i.e., check if the list is corrupt).
Note: The list is doubly and not singly like Data Structure/Algorithm Challenger I, so a solution other then one specified in Data Structure/Algorithm Challenger I is expected.
sahanasome hint please. isnt the one by single linked list considered to be the most optimal?i jus hav a vague idea.may be we can have two pointers that go in opposite directions and if they dont meet means there is a cycle.i dont know where my second pointer ie which is to travel back wards has to point initially because i am not given the number of nodes.
pradeep_agrawal
The solution given for singly linked list may be optimal for it, but a more optimized solution may exist for doubly linked list.sahanaisnt the one by single linked list considered to be the most optimal?
We can't have second pointer pointing to the last node of list because we have only head and if the list is corrupt we never reach the last node. Due to same reason we canit count the number of nodes in the list.sahanamay be we can have two pointers that go in opposite directions and if they dont meet means there is a cycle.i dont know where my second pointer ie which is to travel back wards has to point initially because i am not given the number of nodes.
The basic property of doubly linked list is that every node has two pointers, one pointing to next node and other pointing to previous node in the list. Having an extra pointer in each node surely increase the space complexity, but that will help in giving more optimized solution to the problem in terms of space complexity.sahanasome hint please.
-Pradeep -
pradeep_agrawalNo solution from such a long time 😔
Here is a sample code for the given problem statement. Solution is based on fact that in a doubly linked list, previous of next of a node is the same node. The solution has complexity of O(n).
n[FONT=Verdana]ode *tmp1 = head;[/FONT] [FONT=Verdana]int result = 0; //Specify no circular path exist[/FONT] [FONT=Verdana]while(tmp1 != NULL) {[/FONT] [FONT=Verdana] if(tmp1->next != null) {[/FONT] [FONT=Verdana] if(tmp1->next->prev != tmp1) {[/FONT] [FONT=Verdana] result = 1; //specify existence of circular path[/FONT] [FONT=Verdana] break;[/FONT] [FONT=Verdana] }[/FONT] [FONT=Verdana] tmp1 = tmp1->next;[/FONT] [FONT=Verdana] } else {[/FONT] [FONT=Verdana] break;[/FONT] [FONT=Verdana] }[/FONT] [FONT=Verdana]}[/FONT] [FONT=Verdana]return result;[/FONT]
-Pradeep -
sumitjamihey the above code checks only between the two nodes but instead if we can modify the data node then include a flag.........
1>> initialize all flags to false......
2>> Goto each node serially and in each node check if its flag is already true is so then it means that the node has been already visited once and thus there exits a loopbut if the flag is false set it to true and iterate further........
pradeep_agrawal
Yes this can be a solution but:sumitjamihey the above code checks only between the two nodes but instead if we can modify the data node then include a flag
1. It will need modification of your base data structure, which you may not always want to do.
2. Keeping an extra flag in each node will consume more memory.
-Pradeep
help me with computer interfaced projects
hi, i am a 3 rd year instrumentation engineering student and we have been asked to do a project on any instrument which can...
hey,i m pallavi agarwal..in b.tech 2nd year.....i got struck with this question,plz tell d appt. answer.
hi.i need to write yacc and lex programs.so do i have to necessarily load unix?i came across some thing called cygwin.so is it helpful?all i need is to write yacc...
i want a unique topic for paper presentation and my areas of interest are basically the new gadgets...
what does this statement mean??
void strcpy(char *buffer, char const *string)
