Coffee Room
12933 Members
pikolo23
pikolo23 • Apr 11, 2018
Control I/O by interfacing particle photon with PLC
Hi I wanted to control the output devices by interfacing PLC with particle photon and by using 4-20mA current loop receiver which reads the 4-20mA sensor readings and make the multiple output devices (connected with PLC) work accordingly(as per coded by Particle photon)
What hardware should we use to interface the particle photon with PLC
Suggestion from expertise in this field will be very helpful
thank you
herebo27
herebo27 • Apr 16, 2018
This one is quite confusing but
After checking your links mentioned in your question and with slight knowledge about your problem i was able to check out some hardware
but 1st you need to learn about these hardware functions
you can interface modbus with particle photon or you can also check the current receivers with different channels and their expansion there are many devices available as per your requirement.
hope it help you out
Harshad Italiya
Harshad Italiya • Apr 22, 2018
@pikolo23
Do you have TTL - Serial Interface on your PLC? If Yes then you can connect PLC and Photon by Serial Interface.
