config.trim_on_minimize = true : Free RAM when Firefox is Minimized!
Alright,
I found this comment on lifehacker. Someone commented that if we set
Firefox will return system's precious RAM. Anyone's got more information on this?
silverscorpionconfig.trim_on_minimize??
There is no such field in my firefox, in the about:config page. I'm using firefox 3.1. Is it working for anyone?? -
shalini_goel14
Scorpion right click there and then add new entry of boolean type and set its value to true. If it is not working try making a user.js file(add entry to it) in pref folder of firefox. I tried but it was showing access denied to me.silverscorpionconfig.trim_on_minimize??
PS: I will try more and will get back to you but you also try if it works and let us know. ๐ -
shalini_goel14Wow man, its magic ๐
Add following entry in all.js file in greprefs folder of firefox3 version and save it.
pref("config.trim_on_minimize", true);
When I minimize the window. it is giving quite a bigger amount reduction in RAM consumption.
See just now my Task manager is showing 28,596K against firefox.exe
and when i minimized it, it showed around 3452k. Though it will keep on varying.
I must say a very good information told.๐ -
shalini_goel14But I have a question regarding this- if anyone of you know the reason Please tell ๐
When I made the same changes in my laptop - firefox 3 it didn't allow me to modify all.js file(saying "Access is denied") but just now I tried it in my office system (same version), it is working ๐ How?
Is the directory path matters?
Any ideas anyone? -
ms_csIt is not working for me..I am using firefox 3.07
ms_csA very Useful information this.Also anybody Explain the working of this trick...
shalini_goel14
ms_cs, Did you try the way I told in my post? Are you sure it is not working? Are you getting "Access is denied" Problem? If any other problem let us know? ๐ms_csIt is not working for me..I am using firefox 3.07
Try this Add following entry in all.js file in greprefs folder of firefox3 version and save it.
pref("config.trim_on_minimize", true); -
ms_csAmazing...Its really freeing the ram...May I know the working of this?
Kaustubh KatdareAccess denied? Maybe you've your firefox running? Do you get the same error when you try to edit the file when FF is closed?
Kaustubh KatdareHere's more information: Config.trim on minimize - MozillaZine Knowledge Base
It says that you should leave it to 'false' to maintain application responsiveness. Anyone's seen delayed response time when the setting is 'true' and FF is maximized (from the tray)? -
ms_csI did not even get a single error.In the last time login in my system, i was modified that file.At that time it was not working.when i attempted to restart my system, I got the thing.It is now really working.
shalini_goel14
Man, My firefox was already closed while changing the file. See the error message which I am still getting. I gues it may be beacuse of location? Has anyone tried to the change file in following location? ๐The_Big_KAccess denied? Maybe you've your firefox running? Do you get the same error when you try to edit the file when FF is closed?
Kaustubh KatdareRun 'Notepad' in Admin Mode. [I posted procedure to do so few months ago, please search]
shalini_goel14
Well everything I do on my system is in Admin mode for me. I don't know which Admin mode you are talking about. Just now I tried installing firefox again in C:\ location instead of C:\Program Files , now it allowed me to change that file though I could not see magic of this statement anymore ๐The_Big_KRun 'Notepad' in Admin Mode. [I posted procedure to do so few months ago, please search]
Following is the link that you are talking about and have posted almost a year back(not months back ๐) ๐
Thanks for the information. Good link ๐ -
Kaustubh KatdareHere it is -
Follow these steps:-
1. Click on Start Button
2. Rt. click on 'Notepad'
3. Click "Run As Administrator"
4. Click "Continue" on the prompt
5. Navigate to C:\Windows\System32\drivers\etc\ using Notepad's 'Open' location option.
6. Select 'all files' and then choose the 'hosts' file. Make necessary changes and save! -
cpusrvcI have been playing with this today. FF is open, and Task Manager running and set to "on top". Processes list shows FF is using 130k mem, 251 VM. Minimize FF, mem drops to 18k, VM is same. Over the next minute or two, not touching the computer, mem slowly creeps up to 118k, VM is same.
It seems like the setting must clear out work space memory, and then immediately starts to fill it again as FF does it's thing. I guess this setting isn't much of a help.
I started this blog for all electrical students pls join this and share your feelings
https://sai353.blogspot.com:cean:
now i am doing this survey job in free time at my home,if any one interested on this go to the link below,i hope you also enjoy this job
Stratasys Introduces New FORTUS Brand For High-End Product Line As Direct Digital Manufacturing Gathers Momentum
Besides Prototypes, Customers Use Machines to Make Production Parts and Manufacturing Tools
FRANKFURT, 26 February...
HI,
I'm currently using a microcontroller 16f877A. The Tx and Rx pins of my microcontroller will output either 1 or 0 respectively. The microcontroller is connected to my laptop using...
Hey! our college's CS department is going to organize competitions any ideas for competitions rather than c/c++ programming competitions ๐
