Colloquium: Virtualization in Software Testing - Questions/Discussions
Check this entry at :
Saandeep SreerambatlaCB congratulations for your fantastic presentation.
I read it , its nice.
I have a couple of questions but will check and will post them here. -
Kaustubh KatdareGood presentation. On slide #4, you mention -
It provides isolated sandboxes for running applications and presents homogenous environments even on heterogeneous hardware
1. Could you explain the point in more detail?
2. What are the typical situations where such environments are needed? -
Anil JainThanks Biggi and E-S for the appreciation !!! Biggi, my try to explain your doubt is as follows:
Homogeneous environment
Hardware and system software from one vendor; for example, an all-IBM or all-Windows shop.
Heterogeneous environment
Using hardware and system software from different vendors. Organizations often use computers, operating systems and databases from a variety of vendors.
These are the environment definations from The Latest Technology Product Reviews, News, Tips, and Deals | PCMag. Now, I will try to answer your query using a scenario, and will hope that it will answer your question.
Example:- A testing team needs to test an application which supports the microsoft applications (Obviously first they will get support from windows OS). Team test the same on a machine on which windows Xp Prof is installed.
In next build (after further development) the application got the mac and Linux support as well. Now the problem arises in front of testin team is
1. They do not have the enough hardware to install 3 OS (Windows, Mac, Linux)
2. For mac they need an Apple computer to make homogenous environment.
Now test lead of Testing team suggests the use of Virtualization technique, in which he just increase the RAM (to 4 GB ) of the base machine, installed 2 Virtual machine managers aka VMM's (for linux and Mac). Now he installed the mac and linux on the respective VMM's.
After this testing team would be able to test the application on all 3 OS (Homogenious enviornment on heterogenous harware). No need to say about the cost saving.
Do let me know if I sound a bit confusing anywhere in explanation, or if your query need more explanations.
More Questions are welcomed.
-CB -
ms_csNice PPT CB. I dont know much about testing but know a little about the virtualization. Whether if we use "software as service" concept for testing will it be more efficient than the "virtualization in testing"?
Anil Jain
Thanks !!!ms_csNice PPT CB. I dont know much about testing but know a little about the virtualization. Whether if we use "software as service" concept for testing will it be more efficient than the "virtualization in testing"?
However, I couldn't get you why do you want to compare "software as service" and "virtualization in testing"?
I hope that you do not wanted me to keep the name of the presentation as "software as service".
Actually Virtualization is a concept, and in its simplest defination If I will describe this it would be, "Something which is not actually present however it pretends/works as it is available for use". If I will take an example, we require to perform testing on 5 systems and we do not have number of system (hardwares), still we can use virtualization to fulfill our need of various system.
Please, do let me know if this clears your doubt. Or could you please rephrase your query so that I can answer this in a much better way?
-CB -
ms_csI heard "software as service" as an option for testing. Now From your presentation I aware that virtualization is an alternative for testing. I want to know which method is efficient.
Kaustubh Katdarems_csI heard "software as service" as an option for testing. Now From your presentation I aware that virtualization is an alternative for testing. I want to know which method is efficient.
@ CrazyBoy: Above comment attracts my next question. Do you think "virtualization is an alternative for testing"? ๐ -
ms_cs
@Big_K: CoolThe_Big_K@ CrazyBoy: Above comment attracts my next question. Do you think "virtualization is an alternative for testing"? ๐
That comment should be,
I heard "software as service" can be used for testing . Now From your presentation I aware that "virtualization in testing" as an alternative. I want to know which method is efficient. -
Anil JainHey Hey Hey !!!
I am afraid that you are taking it in a wrong sense. "Software as service" and "Virtualization in testing" is two entirely different things. I tried to explain virtualiztaion as a medium to do the testing task. I never meant to say that we can use virtualization as an alternative for testing.
Rather, at first I named my Presentation as Virtualization in software world. But After adding the testing case study I renamed the presentation to Testing environment.
If this clears your doubt, probably you can start a new thread for "software as service" concept. There are many senior IT Testing pros who can explain software as service concept in much better way.
Hope this cleas the doubt. If not, next query is welcomed.
All CEan's I wuold be more than happy to answer your doubts. -
Anil Jain
@ Biggi, does my presentations sounds like we can use virtualization as an alternative solution for Testing. I hope Biggi is not making fun of me ๐The_Big_K@ CrazyBoy: Above comment attracts my next question. Do you think "virtualization is an alternative for testing"? ๐
My Apologies, If I am sounding a bit offensive
Sire, Virtualization is a medium to do the testing or development or any other IT related task. Using virtualization we can reduce the cost, save time and resources and optimize the time/cost for testing/devlopment. Certainly virtualization can not be considered as an alternative for testing.
However, if prject is sizable then Virtualization is testing can be considered as one of the best technique to optimize the time and cost for the testing and development of the product/project. Hope this clears your doubt.
Again, if doubt is not clear more discussion on the same question is welcomed.
-CB -
ms_csOK.
Should We virtualize the storage too or the existing is adequate ? -
ms_cs
I didnot say virtualization as an testing or an alternative. I said virtualization in testing can be alternative to software as service in testing.crazyboyCertainly virtualization can not be considered as an alternative for testing.
-CB
let me know if still my question is not clear -
Anil Jain
Yes, definately we can virtualize the storage as well. However, it would be benefetial only when the project is sizable and would last for around a year or more. Other wise virtualization of storage would not give you desired ROI.ms_csOK.
For more explanations:
As per wikipedia we can define Storage virtualization as "Storage virtualization refers to the process of abstracting logical storage from physical storage. The term is today used to describe this abstraction at any layer in the storage software and hardware stack."
Reference: Storage Virtualization
-CB -
Anil Jain
Yup, It can be. if project is sizable enough and testing is required to be done in number of builds then Virtualization is testing can definately be considered over "softare as service" and can be rated as one of the best technique to optimize the time and cost for the testing and development of the product/project.ms_csI didnot say virtualization as an testing or an alternative. I said virtualization in testing can be alternative to software as service in testing.
-CB -
ms_csHmm. Thanks for the Kind response
Kaustubh KatdareInteresting discussion building up here.
@CB: Could you tell us cases in which virtualization would fail or may not be a good choice? -
Anil Jain@ Biggi - As always, You caught me in my own territory ๐. Some of the virtualization limitations are as follows:
1. Virtualization is preferable for sizable / bigger projects only. As, for small project ROI would not be as great as for smaller projects.
2. We need a lots of space to save the virtual IMAGES. These virtual images are prone to get corrupt very easily if we do not handle them properly. So anytime we should have backup of these images.
3. VMWare / IBM / Microsoft had there monopony in market, so it creates dependency on these VMM vendors.
I hope this answers your doubts upto some extent.
-CB -
madhumurundihi, CB Good Presentation .. as well as Good topic which is very much holds good for todays Software Companies
I have one question ๐ ๐
1. Can you give me an Example of Network Virtualization ?? -
Saandeep SreerambatlaCB I have a question,
Using this VM technology can we install QTP in one server , LR in another and doing some manual in our local Parallely?
Since when I execute QTP scripts it takes the control over the system So can we use another machine minimising it?? -
Anil JainWOW!!! so many questions ๐, I will go one by one.
@ madhumurundi - VLAN and VPN network's are most common example of Network Virtualization. Do you want me to explain VLAN / VPN ??
-CB -
Anil Jain
@ ES - Yes, We can do this. Infact these are the scenarios we use while doing automation using virtualization technology. Generally we use a poserful machine with 4 GB RAM than install 3 VM's one with QTP Image, another LR image and third with manual configuration. Also I have the base machine to note down the results or perform some basic testing. By this way we can do the 3 types of testing (Functional Automation / Performance and Manual) on the same box.
@ ES - Yes, we can do this. VNC would help me in doing this thing.
Pals, do let me know if this answer your doubts.
-CB -
Saandeep SreerambatlaThis is out of scope question may be !!
But the question is If you install QTP in Virtual Machine and run it on windows application is the behavior same as running it in normal machine.
Since for few actions on windows we need the control to QTP completely.
Like clicking on message boxes , alerts etc.
The same question again IS installing QTP in VM ware and running it is same as running QTP in local machine when the machine is being locked ? -
Anil Jain
This question falls very much in the scope. And you can ask anything which falls within my knowledge, I would be more than happy to answer thatEnglish-ScaredThis is out of scope question may be !!
Once you install QTP on your virtual machine, after that it will behave like your base machine only. Though you need to install VMWare tools (Just like some plug-in) , after that You can perform all the tasks which you can perform on your base machine.
-CB -
estherpolahi every one.. Could anyone please tell how big the project has to be to use virtualization ?some one mentioned that virtualization is not suitable for small projects.can we not just do software testing by installing and uninstalling different operating systems on one PC?
pls help me answering my question asap
thanks -
estherpolasay for example i want test a software application in different versions of windows operating system,do I need to use virtualization ?
pls help asap
thanks -
Anil Jain
For usage of Virtulizations project size need not be huge. However its ROI can be easily seen in bigger projects,estherpolasay for example i want test a software application in different versions of windows operating system,do I need to use virtualization ?
pls help asap
thanks
For your scenario, if you have one hardware system and you need to test your appication on different flavours of OS, virtulization suites best to your need.
-CB
Colloquium: Nanotechnology Critical Endeavor in Cancer - CrazyEngineers
hi..
Iam doing my masters in computers and communication.
i dont have any idea about starting with a research...
i would be helpful if some one guides me wat kind...
Can anyone help a man (who has been kicked out of his group When they got my idea) for a different project to take revenge?
Please help me with a...
I'm a final yr MECH student.....I need COMPOSITE MATERIAL book......My exams are next month plz suggest me...
I need help with this--
Calculate the maximum power used by a three-and a half digit seven segment LED display with a 5v supply and a 10ma LED current. Also...
