  3. Groups >
C++ on uBuntu : fatal error:library iostream.h not found
Question asked by madhuri thalluri in #Gadgets on Apr 26, 2014
madhuri thalluri
madhuri thalluri · Apr 26, 2014
Rank D3 - MASTER
hi...when i write a simple hello c++ program and executed in ubuntu13.0 its showing fatal error:library iostream.h not found like dat..wen i tried to install g++compiler using apt get command its showing something like these packages are not existed..now what should i do???i want to execute c++ programs???can anyone tell what is the problem nd what i should do for it?? Posted in: #Gadgets
Abhishek Rawal
Abhishek Rawal · Apr 26, 2014
Rank A2 - PRO
That's because GNU GCC-C++ (aka g++) doesn't accept "iostream.h" syntax.
Just use
madhuri thalluri
madhuri thalluri · Apr 27, 2014
Rank D3 - MASTER
Abhishek Rawal
Just use
sryy abhishek...i tried it..but its showing error that "cout is not in the scope of int main()"...
Abhishek Rawal
Abhishek Rawal · Apr 27, 2014
Rank A2 - PRO
madhuri thalluri
add this line
using namespace std;
below [HASHTAG]#include[/HASHTAG]
It should look something like
#include
int main()
cout << "CrazyEngineers";
If this too fails, then you might've made some mistake in installing compiler.
Re-installing libstdc++-dev and g++-multilib can fix it.
Click to Log-In or Sign-Up
