Best Electrical and Electronics Engineering Project Ideas and ares of research
Softwares/Hardwares useful to learn:
C, C++, MATLAB, VHDL, VERI LOG, DSP Processing, PSPICE, MOTOR PRO, SYSQUAKE, PSCAD, SIM POWER, KEIL, LABVIEW, Embedded systems, Micro controllers and Micro processors.
The following can be used for Mini Projects or Major Projects for Undergraduate, Post graduate, Diploma students. Not only this, you can also use them for seminar topics or paper presentation topics.
1. Load scheduling using artificial neural networks
2. Load-flow analysis by artificial neural networks
3. Power system fault detection using wave let transforms and probabilistic neural networks
4. Automatic generation control using artificial neural networks and other AI techniques
5. Load frequency control of two area power system using artificial neural networks
6. Short term load forecasting using artificial neural networks
7. Power system stabilizer based on artificial neural networks
8. Load scheduling using
9. Speed control of D.C motor using fuzzy logic
10. Short term load forecasting using fuzzy logic, neuro fuzzy
11. Efficiency optimization of induction motor using fuzzy logic
12. Automatic generation control using fuzzy logic and other AI techniques
13. Improvement in dynamic response of dc and ac motors using fuzzy logic
14. Simulation of vector controlled scheme for speed control of induction motor drive using fuzzy logic controller
15. Load scheduling using genetic algorithm
16. Speed control of dc motor using fuzzy logic and implemented by 8051 micro controller
17. Identification and control of induction motor using artificial neural networks
18. Design of artificial neural networks for fault detection of induction motor
19. Mathematical modeling and simulation analysis of slip power recovery drive
20. Transient analysis of induction motor using matlab
21. Induction motor stator resistance estimation
22. Design and reliability analysis of power converter for programming interface of ECM
23. Graphical user interface based visual display of operation and performance of a 3 phase induction motor
24. Automatic control of distribution generation system
25. Improvement in dynamic response of dc and ac motors with pid controller
26. Load balancing and power factor correction by using active power filter
27. Simulation analysis of three phase 6/4 switched reluctance motor
28. Performance of PMBLDC motor
29. Chaos- study analysis 30 Adaptive controllers design for permanent magnet linear synchronous motor control system
30. Design of power system stabilizer using pole placement design
31. Performance analysis of unified power flow controller
32. Unified power flow controller (UPFC) based damping controllers
33. Sensor less control of induction motor using adaptive, state space and kalman filter method
34. Evaluation of transmission losses in radial distribution system
35. Allocating the costs of reactive power purchased in an ancillary service market by modified y bus matrix method
36. Optimal placement of capacitor banks in radial distribution netowrks using microgenetic algorithm and fuzzy logic
37. Load flow study of a upfc embedded system
38. Tuning of pid controllers in automatic generation control
39. Load-flow analysis by
40. Augmented load flow analysis
41. AC/DC load flow studies
42. Modeling and simulation of static synchronous series compensator (sssc)
43. D- STATCOM in distribution network for voltage / power factor control
44. Voltage sag mitigation techniques by distribution static compensator and dynamic voltage restorer (DVR and D-STATCOM)
45. integral starter generator (isg)
46. Solution to sparse linear equations and its applications to fast decoupled load flow solution analysis using c and c++
47. Computer applications to power systems- a load flow analysis
48. Intelligent techniques for robust self tuning controllers
49. Design of fuzzy logic controller using neural network
50. PID controller for improved performance by using model reduction method
51. Tuning of PID controller using fuzzy logic
52. Fuzzy logic controller for flight vehicle stabilization
53. Hand written text character recognition using generalized PID gradient decent back propagation algorithm
54. Armature control of DC motor
55. Mathematical modeling and simulation analysis of brushless dc motor (BLDC)
56. Control system modeling and analysis using matlab
57. Optimization of fuzzy logic using genetic algorithm
58. Development of neural networks for system identification
59. ARX identification using GA
60. Automatic break control system using artificial neural networks
61. Fuzzy logic controller for semi active control a
62. Mathematical modeling and simulation analysis of dc motor (BLDC)
63. Robust control of given system with artificial neural networks
64. Simulation of code division multiple ACCES
65. An H-infinity approach to robust channel estimation for OFDM wireless communication analysis
66. Analysis of cardiatic signal using signal processing method
67. Simulation of WCDMA system and DS-CDMA system
68. Implementation of multi user detection using gradient projection method
69. Face recognition using eigen faces
70. Implementation of echo chancellor using kalman filter algorithm
71. Performance of evaluation of spread spectrum communication system using matlab
72. Design and development of fixed cellular terminal
73. MSS reporting terminal
74. Speech recognition using wavelets
75. Sampling rate converter and digital equalizer
76. Adaptive noise cancellation
77. Image and data compression using DCT and MELLIN transforms
78. Developments of test methodology and test cases for ipv6 validation testing tool
79. Blind de convolution for image restoration using matlab
80. video compression by sub-band coding using wavelets
81. sequential jpeg image compression
82. Embedded systems (micro controllers):
83. Two telephone lines intercom
84. Auto control of 3ph induction motor
85. Caller id
86. Code lock
87. Electronic cash register
88. Electronic voting machine
89. Fingerprint security
90. Fire fight robot
91. Home automation over internet
92. Home security
93. Ir remote switch
94. Line follower robot
95. Night light saver
96. Parallel telephone line
97. Password based door lock
98. Remote controlled switch board fan 6+1
99. Rf based auto meter reading
100. Rf based remote control
101. Room light controller
102. SMS through telephone
103. Telephone control motor
104. Temp control fan regulator
105. Temperature indicator
106. Time operated electric control
107. Speaker identification using mfcc and neural networks
108. Speaker identification using K-Nearest Neighbor Technique
109. ECG Arrhythmia classification using Wavelet transform and Neural Networks
110. Text feature selection by TF-IDF method and classification using Neural Networks
111. 2-D Human tracking using artificial intelligence
112. Handwritten digit recognition using artificial intelligence machine
113. System identification using intelligent tools
114. Evaluation of cars based on artificial intelligent paradigms
115. Face recognition using Artificial intelligence
116. Hand gesture recognition using Artificial Intelligence
117. Load flow analysis using artificial intelligence
118. Regression SVM based system identification
119. Power quality event detection using artificial intelligence tools
120. Finger print classification using Artificial intelligence
121. GUI based speaker identification using Artificial Intelligence
122. Optimal path planning for robot navigation using higher geometry maze routing approach
123. Development of Control Laws for Attitude Control of Satellites with Flexible Appendages using Nonlinear Control Techniques
124. Target tracking using sensor fusion
125. 3D motion estimation using monocular sequence of images
126. Robust PID controller design using interval analysis
127. Knowledge based sequential/online learning multi category neural classifier
With best wishes,
85. Caller id
86. Code lock
92. Home security
With best wishes,
Kaustubh KatdareThread stuck. Awesome contribution!
jayu_dakhoreLoad frequency control of two area power system using artificial neural networks
can you give me any idea &material about that -
No need putting the same query in multiple places. Your query will be followed here:jayu_dakhoreLoad frequency control of two area power system using artificial neural networks
#-Link-Snipped-# -
VegaAwsome collection buddy! Keep it up! Hope people pick up some of these and reduce load of CEains to answer 'I want mini prjct idea' qns.
faysal851. Automatic control of distribution generation system and
2. Load balancing and power factor correction by using active power filter.
Can you help me in giving me sum idea and material in above mentioned projects. I have to make my final year project in Bachelors of Electrical Engineering.
Thanks. -
Thesis123Dear Student,
you have to tune the controller parameters, bias and droop using ANN based on ITSE criterion. no of inputs it depends on you..normally error change in error (ACE,DACE) and outputs are equal to no of variables you want to calculate.
With best wishes, -
Thesis123you can refer hadisadat text book you can understand some programming.
sumith123Automatic control of distribution generation system is the best project idea, read this paper (#-Link-Snipped-#) before going to do that project
Thesis123Dear Friend,
I am sorry for not replying you in time.
About LFC using ANN. You take any two area model and see how the conventional controllers are working (like P,PI or PID). Then Take area control errors (ACEs) and change in ACEs as inputs to the ANN and change in frequency as output with ITSE as your criteria. Tran the neural network for minimum ITSE of del f and take those weights/net as your final controller. This you have to perform for different disturbances. Other wise you can go for Model Reference Control where your neural network represents your system. You can go through Prof. Gopals control system book where you find good information after the Liapunove stability Chapter. -
sheilaNeed report for electronic voting machine using fingerprint sensor and gsm modem
EEE_CEAs we know there is an instant demand of renewable energy.. Can any CE through some light on the feasible final year projects in this field..??
PrashiHi, this is a long list, please help me pick up a simple project which will reinforce what I have learned n Ist year EEE. I am looking to do some interesting project during my summer vacations that can give me hands-on experience. I went through the list but am a little confused, where to begin. All topics look very interesting but there are many things I am not yet clear on being in Ist year. Which would be a better topic for m and how should I begin?
dipsikhacan you tell me how to do paper work????/
praba230890I don't think this is really gonna help a person to become engineer. The aim of projects is to kindle ideas or to make an engineer to think and end up with some new ideas which can be designed with the technical knowledge we are gaining in college. Please stop giving project topics and it is better to give project ideas and help them while doing project.
Thesis123Softwares/Hardwares useful to learn:
85. Caller id
86. Code lock
92. Home security
With best wishes, -
busoglusogvery nice! could someone give info about the "night light saver"! i'm going to have research and i'm finding topic about it....thanks a lot
parth 127can any one suggest me a project on control system it should be purely based on control system
cchandansjceGuys can u giv me some ideas about "Home automation over internet " .......
cchandansjcecan u giv me ideas and suitable material for "Home automation over Internet "..... waiting for reply .......
Thesis123let me know detailed description of your interest in the above project
Rupam DasGreat Collection here Thesis. Quite Good. Can we also get couple lines of explanation in some of the topics? Like what is input, what is output and what is new in the project.
gprasathhi to all, im an electronics &communication final year student,i want to do project in gsm and cdma technologies so,please suggest me some good IEEE 2011 projects and also project centers in chennai.......thanks in advance.........with regards gprasath..
Thesis123Hi, you can identify the points you want to monitor in the house..basically what exactly you want to automate in the house? power? security? monitoring? ....depending on that read the data in server and take decisions accordingly.
With best wishes, -
Thesis123Thank you!Its really difficult explain the topics like that, they can search a lot in the net just by copy paste. If at all a particular clarification is required then I am happy to answer you...
saraalihi
is this is good project as final project??
Wireless under water -
AbbanhaidarShort term load forecasting using neurofuzzy. Would you kindly give me some idea and materials to use. Working on an MSC project. Thanks.
insane.nickHi guys i want to learn more about the Power system stabilizer based on artificial neural networks please help me .
mehnaz_baharhi,i was hoping if you could help me with an idea about signal processing and control systems.pls do suggest smthng innovative,thank you.
Thesis123Hi electrical crazy engineers, its long time to come here, any way, i will give reply now onwards....
For PSS stabilizer, we have to find out the K1-K12 constants for given performance index to be minimized by ANN
For load forecasting, use fuzzy for temperature decision and for load ANN... for more details ping me back..bye and have a nice time -
icehariCan you provide abstract for
Sensor less control of induction motor using adaptive, state space and kalman filter method -
rahhhhaHi, I am in final year in Telecommunication.pls help me out with some 'Electronics and communication ' based projects pls😀
Harshad Italiya
Have you checked Project Idea Section? Please have a look at sticky threads.rahhhhaHi, I am in final year in Telecommunication.pls help me out with some 'Electronics and communication ' based projects pls😀 -
senjinhello. I have to do an electronics final year project based on Lab-view, can u give me some ideas and small description.
nisarg kodinaria#-Link-Snipped-#
Q) what happens during overload condition or during peak time,if there is fault on R phase(which im using) Then which phase is auto selected by the device, as other phases i.e Y & B are at overload condition
Q) Is there any effect of overload condition?
plz helpme with this
Can anyone provide information about maze follower robot.The specification is,it must reach the destination in a short interval of time.😕
I Would like to present paper on networking.please suggest me any interesting topic friends.
Hi, i have BSC in communication and MSC in networking,last few years i have been busy with my children.Know I want to begin PHD in communication engineering i need your...
Can any one solve my conflict.
Is it possible to convert 32 Bit memory into 16 Bit memory.
If yes then how?
Give me some ideas.
correct me if i...
We know that when we start our PC BIOS locate DOS to HDD memory
for its execution if Hard Disk is not present than RAM would be the second option....
