Addition of feed water heaters to raise feed water temp.to its saturation point
Generally feed water heaters either low pressure & high pressure are using bleed steam from turbine to raise feed water temp. to as high as possible to saturation level.The advantages being 1) savings in fuel 2) extraction of heat from flue gases & lowering exhaust flue gas temp. 3) Being static in nature no running cost 4) Increase in area of T-Ø chart i.e. work done. However in practice, saturation temp for that particular pressure is never achieved. For example in a typical 210MW Turbo Alternator set, feed water temperature after HP Heater is maximum 275°c when boiler steam pressure is 150kg/cm² while saturation temperature is 350°c .That is 75°c less temp. which is made-up in boiler furnace.Will it be technically possible to add another HP Heater/s to gain this temperature ? This may help in lowering boiler heat rate & economy in fuel/coal.
American Sustainable business movement aims at bringing together all start-up oriented people under one roof to help them. The following lectures were held at the symposium held for the same....
In this video, Maggie Mistal who also happens to be a career consultant shares with you if your starting a business is a right move or not. She talks about...
Unable to penetrate far into social networks, Google is trying everything to everything with a new approach, simpler and trying to capitalize on the shortcomings of its competitors. Enough to...
Blogging I feel is an effective medium of communicating our feelings and thoughts to others. It is a rather lethal effective than Facebook in many ways. However there are many...
Anna Hajare is starting a mass movement against corruption. Everyone should oppose corruption in our country. Only we people help the corrupt and they become confident that no one is...
