2048 - How to win? Tips & Tricks
Stumbled upon this totally addictive game. Trust me, it does not look addictive but I bet a few moves into the game and you would have that 'never give up' attitude kick in. I've just spent last 15 minutes trying to get 2048; but couldn't go beyond 256 π. I'm starting this discussion to get opinions, tips and tricks on how to win 2048 game.
All you need is the arrow keys of your keyboard to move the tiles. When two tiles having similar number touch each other; they add-up.
Link: 2048
Link: 2048
Ramani AswathLooks interesting. Rather tied up shall revert in time.
Harshad ItaliyaI got maximum 512 !
durga chsomeone has already comeup with an AI to solve the game, neverthless when I ran it, the max tile formed is of value 1024. But ,a very very informative discussion about the algorithm is going over in stackoverflow ..
#-Link-Snipped-# -
Read the logic and I had tried to play with the same strategy; but couldn't really go beyond 512 (max number on a tile).durgasomeone has already comeup with an AI to solve the game, neverthless when I ran it, the max tile formed is of value 1024. But ,a very very informative discussion about the algorithm is going over in stackoverflow ..
#-Link-Snipped-# -
durga chThe max I reached was 512 too, but i felt that was only due to my inability to see through the steps in advance.. I followed a logic such as, when I have a tile valued x, I leave it there and start making tile valued x/2, and so on and add then as i proceed the game
Anoop KumarAwesome game.. π
I am rusting on 256 π -
Nayan GoenkaI got to 1024. π Very close to finishing the game. Almost done but i got a bit sloppy. I m sure i will crack it today.
PensuHave been trying it out for past few days. Maximum I reached till 1024. This game is going to be end of me!
Rajni JainNext target is 2048...
Ambarish GaneshTotal luck this -
Pensu
Awesome....good work, man!Ambarish GaneshTotal luck this - -
Kaustubh Katdare#-Link-Snipped-# : Respect, man! I'm stuck at 1024. Did you play with any specific strategy?
I noticed that if I keep all the big numbers at the bottom (left or right), I can get to 1024 easily. But if you use 'UP' moves a lot; you'll end up at about 512 and the game will be over soon. -
Ambarish Ganesh
Didn't employ any different strategy. The only one was - keeping the big numbers (128 and onwards) at any specific corner for as long as I can.Kaustubh Katdare#-Link-Snipped-# : Respect, man! I'm stuck at 1024. Did you play with any specific strategy?
I believe I simply got lucky in this game. π Played it 10-15 times more since this, haven't been able to reach 2048 again. 1024 is the sweet spot I hit maximum.
People have actually developed some algorithms for this game on their blogs. Referring them all now. -
Ambarish GaneshAnother addictive game - DOTS. Personal best so far is 330. π
People have registered scores over 900! [HASHTAG]#ChallengeAccepted[/HASHTAG] -
Dots got more challenging after the latest updates. I gave up playing dots about a month ago. It wastes too much of time. πAmbarish GaneshAnother addictive game - DOTS. Personal best so far is 330. π
Nayan GoenkaThis is it. Finally there. π
Nayan GoenkaChallenge Accomplished AAAANNND Game uninstalled π π π
Nayan Goenka
It doesn't actually matter if you use or don't UP moves. However if you are stacking them in corner array fashion, you will have to lose one move. Depending on the corner you choose, you avoid one movement. Here I avoided UP moves and stacked numbers in descending order in snake fashion.Kaustubh Katdare#-Link-Snipped-# :
Ankita KatdareWith 6 attempts I reached 1024 last night and then it was 'game over' π
The only trick I used was putting all the blocks at the bottom of the square. If you never let the biggest addition block leave the last row, you'll reach 1024 very easily. -
Anoop MathewStuck at 256 ! π³π΄
Update: Got 512! -
Ankita KatdareI am stuck at 1024 + 512. Never go beyond that.
Must. Crack. It. Soon. π -
Kaustubh KatdareSuccess!
Ankita KatdareAnd though I am a late latif, here's mine! π ππ
Ankita KatdareMost of us seem to have used the left-bottom corner trick. π
Basil John
Finally 2048 !!! -
Anoop Mathew
Was stuck at 1024 for last 2 days. Now finally!
P.S.: New passtime at office for everyone π -
Anoop Mathew
And again! Buhahahahahaaaa!Anoop Mathew
P.S: Non-corner win ππ -
Anoop MathewNext Challenge: To win a 2048 in any of the center 4 tiles ONLY! πππ―π
Tuan DoTIP 1 - Do not use the up arrow key unless you have no moves left except that.
TIP 2 - Always try to keep the high valued blocks in the bottom row and try to arrange the scores on the block in the descending order from to Left to right (last row) and then right to left in the second last row in the pattern
TIP 3 - After achieving the above pattern it will be just too easy to get the 2048 tile by merging the 8 and 8 tiles to get 16, 16 and 16 tiles to get 32 and go on until you get the 2048 tile by merging the 1024 and 1024 tile.
P/S: I usually play games at #-Link-Snipped-# 2048, this site has the 2048 version of the game as: flappy 2048, tetris 2048, 2048 hard, 1 game.... -
Ambarish GaneshFlappy Bird + 2048 = Whole new level of crazy!
Here: Flappy48 by Broxxar -
Pensu
HermioneGrangerwell.....that took me a month to do, but eventually cracked it. I don't think anyone has got that far π
ANU SEKARI reached 1876...
Mahesh DahaleReached 1024
Ankita Katdare#-Link-Snipped-# That does put all my previous records to shame!
What spell/charm did you use? ππ -
Anoop Mathew
Do notice the number of squares in her game and the one we played. Its different.Ankita Katdare#-Link-Snipped-# That does put all my previous records to shame!
#-Link-Snipped-#: show us the record with 4*4 squares -
HermioneGranger
#-Link-Snipped-# - thankfully I didn't require any spell. π all thanks to my boring college lectures. I would play this game for 3 continues lectures daily just to pass the time, and eventually I managed to crack it.πAnoop MathewDo notice the number of squares in her game and the one we played. Its different.
HermioneGranger#-Link-Snipped-# - here it is....I didn't reach as far as 8192, coz its a bit of a challenge in a 4Γ4 matrix
HermioneGrangerMy trick was to keep all the heavy numbers at one side. Be it left right top or bottom....Just avoid the centre.
micheal johnreached 2048 and continuing...
micheal john
Reached 2048 and continuing...
What is the difference between isd 1420 and isd 1820..??
Can we replace isd 1420 with isd 1820..??
PLz help me out with this query
chetan : My email id...
may i know about some sensible steering systems that will alert when the driver get collapsed
any motor company implemented yet
A human wearable robot has been developed by Italian Engineers. This robot consist of parts similar to that of human body and are designed to fit a human being perfectly....
Hey everyone.
I own Sony Ericsson Ray (ST18i) with android version 4.0.4. Earlier it was android version 2.0 which I upgraded to the version 4. Due to it, my phone...
Android users, here is a piece of good news for you. A special USB drive will make your task of moving files from phones or tablets to PC easier. Leefβs...
