10x10+0
I hope you will understand the thread's concept from the title. Am little confused with this!!!!๐จ Can anyone help? I need the answer with reason. ๐
yorha 2b100 is answer !
Reason : back to Grade 4, "THEORY OF OPERATIONS" where we learn short-form PEMDAS.
P - Parenthesis
E - Exponents
M - Multiplication
D - Division
A - Addition
S - Subtraction -
gowthamanbuBut many of them said that PEMDAS or BODMAS is applicable only when a barcket is there. No bracket=No PEMDAS. ๐
yorha 2bParenthesis is also known as Brackets.
gowthamanbuSo No Bracket na? Then How the answer will be 100?? It must be zero na sir!!
yorha 2bParenthesis is also known as brackets ... & in PEMDAS .. P stands for Parenthesis, E for Exponents, M for Multiplication, D for Division , A for addition & S for subtraction ...
so as per your question 10x10+0 ..... there are 2 operations i.e. Multiplication (M) & Addition (A) .. according to PEMDAS ..... M comes before A ... so first multiplication .. hence 10x10=100 & then Addition, 100+0 = 100... so 100 is the answer ...
& hey hey don't call me sir ... I cant' swallow this much respect ๐ -
How did you get a zero? Explain.gowthamanbuSo No Bracket na? Then How the answer will be 100?? It must be zero na sir!! -
In any case, you do multiplication before addition. ๐gowthamanbuBut many of them said that PEMDAS or BODMAS is applicable only when a barcket is there. No bracket=No PEMDAS. ๐ -
gowthamanbuI think i posted the title wrong. It must be 10+10x0!!!!!!!!!! APOLOGIZE ME.....๐ญ
gowthamanbu#-Link-Snipped-# Apologize !! 10+10x0 = ????????? Answer 10 or ZERO!
Ramani AswathIn Tamil language alone addition has the same priority as multiplication.
Perukkal (เฎชเฏเฎฐเฏเฎเฏเฎเฎฒเฏ)(multiplication) and Koottal (เฎเฏเฎเฏเฎเฎฒเฏ)(addition) both also mean sweeping.
In arithmetic multiplication has to be done first, even if there are many of them in one expression. Addition is done later.
So 10+10x0 =10+0=10 -
gowthamanbuI Hope that I understood. It is right that BODMAS is applicable in all mathematical expressions..
Neeraj SharmaBODMAS doesn't always imply "Brackets of". We were taught to read it as "Before Operation". BODMAS is universally applicable for all the mathematical expressions
gowthamanbu#-Link-Snipped-# Stood Stood Stood ๐ ๐๐๐๐๐๐๐๐๐๐ Thanks a bunch ๐๐๐๐๐๐
nibhanians
answer will be 100...because in mathmatical calculation we first solve multiplication then addition.....gowthamanbuI hope you will understand the thread's concept from the title. Am little confused with this!!!!๐จ Can anyone help? I need the answer with reason. ๐ -
nibhanians
answer will be 10........gowthamanbu#-Link-Snipped-# Apologize !! 10+10x0 = ????????? Answer 10 or ZERO! -
nibhanithe
the answer will be 10...you will solve first multiplication then addition......gowthamanbuI think i posted the title wrong. It must be 10+10x0!!!!!!!!!! APOLOGIZE ME.....๐ญ -
nibhaniyes
yes u r right...BetterThanBeforeParenthesis is also known as brackets ... & in PEMDAS .. P stands for Parenthesis, E for Exponents, M for Multiplication, D for Division , A for addition & S for subtraction ...
Anil JainInteresting, What would be answer of this?
(2*2+2*2+2-2*2/2)-2*2+2 =?
-CB -
gowthamanbu6 !! ๐ or ๐
gowthamanbu#-Link-Snipped-# Thanks a bunch ๐๐ Well I am only confused huh? Some told me that PEDMAS or BODMAS is not applicable when there is no Brackets in the expressions!!!
nibhania
answer is 6.am i right??crazyboyInteresting, What would be answer of this?
-CB -
yorha 2b
But dude ! P in PEMDAS stands for Parenthesis(also known as brackets by layman) ... so how can PEMDAS not applicable when there is "no" bracket while P itself in PEMDAS stands for bracket ,which is first operation ?? ๐ฏgowthamanbu#-Link-Snipped-# Thanks a bunch ๐๐ Well I am only confused huh? Some told me that PEDMAS or BODMAS is not applicable when there is no Brackets in the expressions!!! -
yorha 2b
I got same answer & i think its correct ๐nibhania
answer is 6.am i right?? -
gowthamanbu#-Link-Snipped-# ๐ Don't Get Angry ๐ !!โ 100% I got now!! ๐
Anil Jainyes 6 is correct.
Ramani AswathDear dear, or should I say dear Anbu, which is the same thing, BODMAS PEMDAS are just nemonics to help remembering something. It is much better to be clear about what is implied.
Brackets are like rooms. Whatever is inside the brackets is a single entity on which the operations out side the brackets are done. Therefore one must first simplify what is inside the brackets. One can have any number of brackets nested, that is one inside the other.
What has to be done in this case? Start with the innermost bracket and go outward eliminating the brackets one pair at a time.
e.g.3x(2+(3x6 +2)) =3x(2+(18+2)) = 3x(2+20) = 3x22 = 66
Next in prority is a single number on which an operation has to be done.
e.g. sin30, 3^2.5 and such. This is because further operations are done after the result of this operation is done
Next is multiplication/division. Last priority is for addition/subtraction. -
gowthamanbu#-Link-Snipped-# Proud Proud Proud of being here!!! Clearly i got it sir...
Lalit77
(10+10)x0=0, 10+10x0=10gowthamanbu#-Link-Snipped-# Apologize !! 10+10x0 = ????????? Answer 10 or ZERO! -
vikaskumar11233The answer is 100.
As it is solved with the BODMAS formula. Bracket Of Divide Multiply Addition Subtraction priorities. So first multiplication 10*10 is solved i.e. 100 & then addition with 0 is performed. So the answer is 100. -
Jeffrey Arulraj
Bodmas gives you 10 I guess cause there is no multiply sign between 10'svikaskumar11233The answer is 100.
vikaskumar11233
If the question is 10+10*0, then by BODMAS formula answer is 10. As, 10 * 0 = 0, then 0+10 = 10gowthamanbuI think i posted the title wrong. It must be 10+10x0!!!!!!!!!! APOLOGIZE ME.....๐ญ
Hence the answer is 10. -
vikaskumar11233(2*2+2*2+2-2*2/2)-2*2+2=
=>(4+4+2-2*1)-4+2
=>(10-2)-2
=>(8)-2
=>6
Answer is 6 . ๐๐ -
Hussanal Faroke=> (4+4 + 2 - 4/2 ) - 4 + 2
=> (4+4+2-2) - 4 + 2
=>8-4+2
= 6. -
kushalbansal6
Ganesh MSD
answer is 10.gowthamanbuI think i posted the title wrong. It must be 10+10x0!!!!!!!!!! APOLOGIZE ME.....๐ญ
10*0=0 then 10+0=10. So the answer is 10.
So friends, do you think Illuminati exists ??
Sometimes i believe so & sometime i don't ...... This conspiracy theory sounds so real, aint it ?
Like Obama said they...
Me & my friend on our way to college ....
after long conversation ...
She : So what kind of PC you own ?
Me : AMD FX4100 AM3+, 4...
After releasing its Android powered tablet KindleFire, Amazon is now all set to release its first smartphone. Amazon has collaborated with Foxconn in development of its own smartphone. Foxconn is...
Am Athish krishna,Studying B.Tech (IT) Final year..
Its rumored that Apple is set to release a 7-inch iPad mini to heat up the competition of the mid range tablets with the likes of KindleFire, Microsoft's surface and...
