What is IPv6?
can anyone give me a brief description about IPv6
kidiee4uvishalhakcan anyone give me a brief description about IPv6
Internet Protocol version 6
Intenet Protocol is used in the Internet Layer of the TCP/IP protocol.IPv6 is the latest version of internet protocol which uses 128 bit address older one IPv4 is using 32 bit address. -
maheshvshetHey,
The IPV6 has come into existance due to the scarsity of the IP addresses. The IPV4 provided at max 2 power of 32 addresses and due to unlimited growth of internet IPV6 was necessary. However it takes time for complete IPV6 era as almost all the protocols (networking - IP ) in existance are written for IPV4 and migration is a pain. Meanwhile the Private IP concept with NAT (Network address translation) has temporarily reduced the need for IPV6.
Regards
Mahesh V.Shet😁 -
babloo0311
sirmvitits new 128 bit internet protocol but we are using ip4 coz its support for all the type machine
silverscorpionFor info about every type of protocols and their versions and all, take a look here:
It's a good site. -
saurabhI will suggest u to refer the book "TCP/IP Suite- By Behrouz A Forouzan"
There u can comparitively study IPv4 n IPv6......
sir im a 3rd year student of elecronics & communication engineering , what is the procedure for applying for summer internship in reputed companies like TI etc. what is the...
Dear All,
I am an electrical engineer by profession. Proud to be to solve the problems to the extent I can help.
cheers 😁
I would like to know that which is anti-corrosive element in mild steel.
What i can do to prevent mild steel from rust (corrosion) in mainly monsoon season ?
I can't take this any longer.
1200 civilians killed.
400 of them children.
They are even using them as a testing ground for experimental weapons.
This is massacre!!! You don't...
hey...!!
in the given circuit...i cant figure out the function of transistor...!!
ie. is it acting as a switch or an amplifier...??
Its a BJt pnp transistor...!!
If it is...
