ThoughtWorks logic assessment test paper - Solutions?
I found some questions from their logic assessment test.
Check them here:
Check them here:
Ankita KatdareA lot of people are writing to me saying they are having a hard time finding solutions to these questions. Anyone here wants to try figuring out the answers?
kanwar singhne1 having some other set of questions?
i have solved these questions -
sheena.gurmyes i want solutions to these ?s as m going to encounter thoughtworks assesmnt in october in colg placemnt
gowthuragtell me the technic to solve logic assesment problem
DivyaBalsai need answers pls
DivyaBalsa
i need answers pleaseAnkita KatdareA lot of people are writing to me saying they are having a hard time finding solutions to these questions. Anyone here wants to try figuring out the answers? -
Start putting up questions one by one OR in a list - and we will discuss the solutions here.DivyaBalsai need answers pls -
nomadtravelerHey Ankita!
Can you please explain how you solved question 3? -
I believe this is the question -nomadtravelerHey Ankita!
Step 1:
2 + 3 = 5
5 in Box 11
Step 2:
8 in Box 10
Step 3:
Yes. The Box number is 1, which is an odd number.
Step 4:
Number in Box 6 = 2
Number in Box 2 = 6
Therefore going to instruction 6
Step 6:
4 + 5 = 9
9 in Box 11.
Step 7:
Box 2 and Box 9
Step 8:
8 !< 9
Therefore, NO.
Step 9:
8 in Box 10.
Answer is
Box 8 has 11
Box 11 has 9
Solved it in a jiffy. Please correct if I am wrong. -
nomadtravelerThanks so much for such a quick reply! I messed up on the question numbers though π Calculated the sample tests as questions as well. My bad.
I was actually referring to problem 1 and problem 2 (Image number 3) -
Could you share your solution with us please? We can verify it and discuss the correct solution. πnomadtravelerThanks so much for such a quick reply! I messed up on the question numbers though π Calculated the sample tests as questions as well. My bad.
nomadtravelerSure! For Problem 1, my answer was 27. Is that correct?
A step by step solution I meant. It will be useful for fellow engineers who want to know the procedure to solve these problems. πnomadtravelerSure! For Problem 1, my answer was 27. Is that correct?
There are no correct solutions available. -
nomadtravelerEmm, there has to be a correct solution. Not putting in the step by step process primarily because, if it is not the right one, I don't want others to get confused. Sure I can put it up if I know that the answer is right.
sharad225hello Ankita, Could you show us how to solve problem numbers 4, 5 and 8, please? Doing step by step would be helpful, the way you showed solution to one of the problem above in this thread. I am not talking about the sample problems. appreciate your help.
usheCould u pls solve this step by step? Thanks a ton!
osheen rainaplease help me solve these patterns.i have interview on 22nd.. my id is #-Link-Snipped-# and tell me the easy steps to crack the tech interviews as i am from non IT field.eagerly waiting for your reply
niksw7Ankita KatdareI believe this is the question -
Step 1:
2 + 3 = 5
5 in Box 11
Step 2:
8 in Box 10
Step 3:
Step 4:
Number in Box 6 = 2
Number in Box 2 = 6
Step 6:
4 + 5 = 9
9 in Box 11.
Step 7:
Box 2 and Box 9
Step 8:
8 !< 9
Therefore, NO.
Step 9:
8 in Box 10.
Answer is
Box 8 has 11
Box 11 has 9
Go to statement 3. U need to start again from 3 and not just end at step 9 -
chaitanyaMcould you please explain me step by step procedure for this below problem...plz provide solution as early as possible,because I have exam on 5th dec,2014..
ANURADHAM89can you plz solve the problem four
ANURADHAM89is the answer for problem 4 .............6
Ankita KatdareAnyone up for solving this problem?
READ THESE DIRECTIONS:
In the following problem you are told something about the result, and you must determine what the content of the boxes must have been, in order to obtain the result.
In these problems, the expressions (number in box x) is abbreviated as (x)
In each of the following problem no two boxes contain the same number.
The object of the following flow-chart is to rearrange the numbers in boxes 3, 4 and 5in such a fashion that, at the end:
Box 3 will always contain the smallest number,
Box 5 will always contain the largest number,
However, this flow-chart is INCORRECT. As it stands, it will not accomplish the desired purpose. Which one instruction must be changed to correct the flow-chart?
In order to correct this flow-chart, we must change Instruction No. ______
So that the first box-number mentioned in it is box-number ______
And the second box-number mentioned in it is box-number ______
#-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# #-Link-Snipped-# -
Kuldeep AggarwalAnkita KatdareI believe this is the question -
Step 1:
2 + 3 = 5
5 in Box 11
Step 2:
8 in Box 10
Step 3:
Step 4:
Number in Box 6 = 2
Number in Box 2 = 6
Step 6:
4 + 5 = 9
9 in Box 11.
Step 7:
Box 2 and Box 9
Step 8:
8 !< 9
Therefore, NO.
Step 9:
8 in Box 10.(I think, here we have done a little mistake, we need to put value of Box2 in Box9, i.e. 6 in Box 9)
Answer is
Box 8 has 11
Box 11 has 9
So again,
Step 3
No, Box number is even # => Move to step 6
Step 6
9 + 4(box5) = 13
step 7
Box 3 and Box 8
step 8
8 < 8 ? No, go to step 2
step 2
Put "5"(box 3) in Box 8.
step 3
Yes, Box number 3 is odd.
Number in Box 6 = 2
Number in Box 2 = 6
step 6
put 13(box 11) + 4(box 5) in box 11
step 7
Box 4 and Box 7
step 8
7 < 8 ? Yes, => END
value in Box 8: 5
value in Box 11: 17
p.s.: Please correct me if I took any wrong step or misunderstood the question. -
Kuldeep Aggarwal
I got 14.ANURADHAM89is the answer for problem 4 .............6
Step 1
put 9(box 12) - 0(box 12) in box 2
step 2
Box 12 and Box 14
step 3
We can't let the condition be false as there is no Box 14, so we have to put "14" in box 3 to make the condition 14 == value in Box 3 be true.
so the answer might be 14. -
Sujith EthanHuntHi Ankitha,
I hope you are doing fine, I was just trying to solve this questions. In sample question 2 they gave answer has 11 but I'm getting 8, could you please tell me how to solve this.
Thanks in advance. -
timerHi Ankita,
Can u please explain one problem from each section? -
prachi agrawalthe ans of 1st question is 20...is it correct..please provide me the solutions..needed urgently..have interview on monday..
ugomarthe answer of the problem1 should be 27
Nitincoolplz provide me answers on #-Link-Snipped-#
Jassi Kaursee I try solving the paper and i got these as the answers Please tell if any of them is wrong
Problem 1 ans-27
problem 2 ans 22
problem 3 ans 5 and 17
problem 4 ans 8
problem 5 ans 7
problem 6 ans 11
problem 7 ans 4
and rest I have not solved
Please tell if they are correct -
Jassi KaurPro
problem 1 answer is 27 not -27 sorry for the mistakeJassi Kaursee I try solving the paper and i got these as the answers Please tell if any of them is wrong
Problem 1 ans-27
problem 2 ans 22
problem 4 ans 8
problem 5 ans 7
problem 6 ans 11
problem 7 ans 4
DILIP KUMAR Esolution of problem 6-10
kaka ji amupls give me the solution of this question
Vineet AgrawalCan someone give the step-by-step solution for problem no. 6, attached here
Vishal Sangave
Same answers I gotJassi Kaursee I try solving the paper and i got these as the answers Please tell if any of them is wrong
Problem 1 ans-27
problem 2 ans 22
problem 4 ans 8
problem 5 ans 7
problem 6 ans 11
problem 7 ans 4
Problem 8 ans Largest=2 and Smallest 1
Problem 11 ans Step to change is Step 1 First box should be 3 and then 4 -
Jacopo MarcantonioHi could anyone please help me with the step by step solution for problem 8,9 10.
I cannot understand how to tackle them.
Thanks,
Jacopo -
Swati_5868Hi.. Can anyone please tell whats the meaning of "Change Instruction 2 : increase the sencond box number mentioned in it by 1" in sample test 2. ( Same kind of sentence is mentioned for problem 2 also) i am not able to get its meaning and i think because of which i am not able to get correct answer. Please Please reply asap.
Ankita Katdare#-Link-Snipped-# Could you post a screenshot of the problem you are trying to solve? We could understand it better that way.
NOOTHANTHOUGHT WORKS is going to visit our campus soon.
can anyone help me with more FLOWCHART based problems and CODING PROGRAMS to clear the first two rounds.
thank you, -
Aishwarya MittalCan anyone help me with the solution of prob-2. I got stuck in loop.Please help asap
narendra hmf
narendra hmfor problem 2 answer should be 19
Aishwarya Mittal
Can u give me the solution ?narendra hmfor problem 2 answer should be 19 -
Aishwarya Mittal
Can u provide us solution of problem statement 11 ? How u reached this conclusion? Thanks in advance!!someoneUnkownSame answers I got
dayal1234
escume me... i have found some solution own my own.. but still which is blank i m not able get the concept of these questions..Ankita KatdareI found some questions from their logic assessment test.
Check them here:
please help me and responce ASAP..
thanks -
dayal1234
Bro i need that 5 image question which is blank how to fill tht not able to get the logic behind tht.. or can say not able to get these questins.. πkanwar singhne1 having some other set of questions?
teel me logic beghind it.... or mail me Solutions PLEASE -
jayalakshmi abhinayahi every oneπ.. how do you solve that one??π...what are the logic behind like this???π...flow of the program could not understood myselfπ³...if any one known that logic explained πππ
dayal1234
only first type of question i understoodJayalakshmi Jayabalhi every oneπ.. how do you solve that one??π...what are the logic behind like this???π...flow of the program could not understood myselfπ³...if any one known that logic explained πππ -
nameless129
in step 9 control goes to step3. after that dont we need to slove 4,5,6... steps again?Ankita KatdareI believe this is the question -
Step 1:
2 + 3 = 5
5 in Box 11
Step 2:
8 in Box 10
Step 3:
Step 4:
Number in Box 6 = 2
Number in Box 2 = 6
Step 6:
4 + 5 = 9
9 in Box 11.
Step 7:
Box 2 and Box 9
Step 8:
8 !< 9
Therefore, NO.
Step 9:
8 in Box 10.
Answer is
Box 8 has 11
Box 11 has 9
Prajkta Kedare
I want answer of above question, any one have answer please reply quickΒ
#-Link-Snipped-#ΓΒ - Where exactly are you stuck? Looks straightforward to me. You simply have to keep iterating it.ΓΒ
According to today's reports in TOI, Amazon Offices in Bangalore, Hyderabad and Chennai, that create solutions for the ecommerce operations are all hiring (despite a slowdown) Amazon is going to...
*Engineering Trade: IT
*Occupation: Analyst Programmer
Work Experience: 4 yrs
*Hobbies & Interests: Singing and reading spiritual books
*Aim in life: To become CEO
*I...
Hi all,
I am thinking of buying a new laptop. My range is 30-35k. Please suggest. I've used Dell Vostro 1040. It's good till now but i had faced problem...
Hello everyone, I am a final year Computer Science student, can you please suggest me a topic for my final year project. Please.
My spoken English sounds as if I am out to take revenge from Britishers for exploiting Indians till 1947.π
But that's not the case.π
I love the language very much...
