The Spartan
Project Abstract / Summary : Our plan is to make a fighter jet which would have 2 special uses. They are:-
• Fast means of transport for military purpose.
• This is a fighter jet which is capable of carrying tons of explosives and bombs and also about 20 soldiers with two 1 small military truck.
It has 3 special engines which increases its speed even with full payload. It has its special design and its mid thrust on its tail which keeps the aircraft stable in the air. An air inlet which is a 25 cm hollow tube between the aircraft which becomes narrow in the middle decreases the air pressure and increases the speed of air making the air to be pushed inside the air filter of the turbofan engine and power it to its full speed. It has special weapons like powerful machine guns, missiles and a dam buster bomb. These bombs and ammos I all would weigh much.
Hence we have 3 thrusters which would in total give more than 95000 lbs of thrust. Its main feature
is, if it invades a country it doesn't have to take precautions of enemy's attack. Its cockpit and the ammo & bombs box which contains programmed missiles, explosives of huge destruction has been made stronger with Duralumin which would keep it safe during any attacks. . If the aircraft is damaged the aircraft will dismantle and the cockpit which has a type of small wings would eject and start its small propelled engine with a 200 liter fuel tank. Other parts will fall down and all programmed weapons will be engaged in finding the enemy’s territory and if the aircraft is safe then it will return by ejecting only the explosive compartment which will destroy the area. Imagine if a single aircraft can do so much what will be the effect if hundreds of such aircrafts are with India? Its name “SPARTAN” itself defines its strength.
Weapons:
Standard: M-2 Browning Heavy Machine Gun, Javelin and Astra missiles, MU-90 Torpedoes,
BLU-82 bombs, a dam buster bomb and many more…
Emergency: Programmed missiles and hugely destructive bombs which are programmed to attack different areas of the enemy’s territory only.
Emergency exit for crew and attacking in enemy’s territory: First while entering the territory it will launch a dam buster bomb which will be difficult to resist from such a distance. Then it will use the standard weapons and will strike missiles.
If it gets hit it will dismantle all the parts and the cockpit and small fuel chamber will be ejected and folded wings will come out and they will be evacuated. And the special weapons chamber will get engaged and all the weapons will distribute all
over the enemy’s territory. Otherwise it will be safe in its place in its hard duralumin case.
Engines:
Why did you choose to work on this project topic : India has not invaded any country since thousands of years...Even if our country is not invading another country it should have a good technology for good defense. So for helping the Indian defense we are trying to make a jet fighter aircraft which could save our people and would destroy the enemy’s territory only if required without harming the aircraft crew.
Institute/College Name: Arya Gurukul
City: Kalyan
State: Maharashtra
Weapons:
Engines:
- 2 Pratt & Whitney J58 with afterburners
- 1 Pratt & Whitney F119 with afterburners
- Fuel:
- Normal Aviation Fuel
- If possible, for higher speed RP-1(Rocket Propellant) should be mixed with the fuel.
- In normal conditions, used cooking oil technology can also be used for powering the engines for lesser carbon emissions.
City: Kalyan
State: Maharashtra
Ankita KatdareRound II Project Entry:
Digital Locker is one of the key initiatives under the Digital India Programme. A beta version (https://digitallocker.gov.in) of the same has been released on 10th Feb. 2015, by Department of...
Project Abstract / Summary : concrete is second most consumed materials in the world after water.concrete made up of cement,water ,fine and coarse aggregates.In order to make high strength concrete...
Since the advent of laptops, tablets and cell phones, there has always been the speculation that desktops are going to be dead sooner or later. Still, there are many of...
Two weeks ahead of the biggest tech event of the year, the 'Mobile World Congress 2015' is set to kick off, rumor mongers have laid there hands on some of...
In what could be the world’s largest bank theft ever, hackers have been successful in stealing about $300 million from banks and other financial institutions all over the world. As...
