The First law of Thermodynamics.
It states that "Energy can neither be created nor destroyed, but can be converted from one form to another".
Now applying this law to a machine used in our daily lives, for example, a centrifugal pump, this is what happens:
The motor converts electrical to mechanical energy. The mechanical energy is then converted to fluid energy by the pump. when the water is moved to the tank on the top of the terrace, the fluid energy is converted to potential energy.
what happens after this ? where does all the energy go , if it is not destroyed according to the law ? even if it is lost to the atmosphere, then how exactly ?
Siddhant Mukherjee@#-Link-Snipped-# The potential energy gained by water is the energy needed for it to flow further. You cannot expect water rushing out through your tap until and unless it has some kinetic energy. So, if you apply Bernoulli's theorem (which is again based on conservation of energy) to the water in tank and the water coming out of your tap you will find that the potential energy loss of tank water has changed into pressure energy and kinetic energy of water at tap. The kinetic energy of tap water is again lost in small deformations made on your bucket's surface. So, energy goes no where it has just changed its form.
As the automobile companies in India and across the world gear up for the 2014 Delhi Auto Expo in India, Datsun - the automobile brand owned by Nissan Motor Company,...
"Many people are unable to prepare for the future because they are too busy rehearsing the past"
Every document is important when it comes to finances, insurance papers are needed...
Rounded-Dark theme I have created which suits the best for circled-icons, the source-code is available at GitHub : https://github.com/AbhishekRawal/Rounded-Dark
You'll need plank dock(comes pre-installed in elementaryOS), which you can install...
"The most hopelessly stupid man is he who is not aware that he is wise."
When buying a financial product always factor the hidden costs. Sometimes these costs are overlooked...
The JILA Strontium Atomic Clock is the new God of time keeping - and it's going to do the job till the end of the world. The creators of the...
