1. CrazyEngineers Success
    Introducing CrazyEngineers IO
    Get access to special apps designed to make every engineer a winner!
    Get Started For Free
The CE Coding Challange
Discussion in 'Computer Science | IT | Networking' started by Sanyam Khurana, Sep 7, 2013.
  1. avii
    avii Star
    Engineering Discipline:
    Computer Science
    Code:
    binstring = '1010101010'
    newstring = '1'*(len(binstring) - binstring.count('0')) + '0'* binstring.count('0')
    • Like Like x 2
  2. Vishal0203
    Computer Science
    i'd appreciate a solution in C. And, convert the same input string instead of using a new one
  3. avii
    avii Star
    Computer Science
    ^I don't like C. So used Python. and strings are immutable in python, so its not possible to 'convert' it
    • Like Like x 1
  4. Vishal0203
    Computer Science
    I know python strings are immutable, I mentioned the conversion for C. Python also provides a bunch of predefined functions which are so good that you don't actually need to think much whereas C makes you think and that is what expected. I would not like to continue the discussion over the strength of programming language. Anyway, let someone else answer it in C!
  5. Harshad Italiya
    Moderator
    Electronics & Communications
    Array of binary number. Do you mean like this
    Code:
    Array[]="10001101011101" ;
  6. durga
    durga Star
    Communications
    avii's solution was best. but a non-pythonic way of doing it (elaborate).
    s = '100110111101'
    sn = '' # intiatize a new str
    for i in s:
    if i =='1':
    sn += i​
    sn += ('0' * (len(s) - len(sn)))
    prints '111111110000'
    • Like Like x 1
  7. Harshad Italiya
    Moderator
    I am not sure if I understand your question properly but here is one lengthy code without thinking too much.
    http://codepad.org/0O4AvECS
    Code:
    void main()
        unsigned char tuArray[]="1110111";
        unsigned char tuArraySize;
        unsigned char tuCnt;
        unsigned char tuNoOfZero=0;
        tuArraySize = strlen(tuArray);
        //Findout no of Zero
        for(tuCnt=0; tuCnt<tuArraySize; tuCnt++)
            if(tuArray[tuCnt]== 0x30)
                tuNoOfZero++;
        for(tuCnt=0; tuCnt<(tuArraySize-tuNoOfZero); tuCnt++)
            tuArray[tuCnt] = '1';
        for(; tuCnt<tuArraySize; tuCnt++)
            tuArray[tuCnt] = '0';
        printf("%s",tuArray);
    • Like Like x 1
    #167 Harshad Italiya, Jun 17, 2014
  8. Vishal0203
    Computer Science
    how about converting the same string to the required form?
  9. Vishal0203
    Computer Science
    don't you think you made it more complicated? :) it can be done in one pass.. think that way!
  10. Harshad Italiya
    Moderator
    It can be as I said I have not thought too much on that as I am not sure if I have understand your question properly. But Now I will try to get some easy way. :)
  11. durga
    durga Star
    Communications
    not possible. That of code was made in python
  12. Vishal0203
    Computer Science
    Oh my god! I'll stop commenting
  13. SurEC93
    SurEC93 Rookie
    Hello all! The new version of forum is cool:)
    It's been a while I have practiced these kind of c programs.
    Below is one that I was trying.
    printing magic numbers: a magic no is a no that is same as the sum of factorials of its individual digits.
    (eg. 145= 1!+4!+5!)
    Code:
    void main()
    long int x,n,p,a[10],c,temp,q,sum,s[10];
    clrscr();
         for(x=1;x<=100;x++)            // checking for no.s from 1 to 100
        c=0;
        sum=0;
        p=x;
        temp=x;
            while(temp!=0)            // to find no. of digits in no
            temp=temp/10;
            c++;
            for(n=1;n<=c;n++)
            a[n]=x%10;
            x=x/10;                // separating the digits
            for(n=c;n>0;n--)
            s[n]=1;
                for(q=a[n];q>0;q--)        // eg 5 then it will run 5 4 3 2 1
                s[n]=s[n]*q;        // finding factorial
            sum=sum+s[n];            // taking sum of factoials eg. 1!+9!+5! for 195
        if(p==sum)                // checking criteria
        printf("%d \n",p);
    Can't get what's wrong. Plz figure out.
  14. Vishal0203
    Computer Science
    That's a very complicated code you've written and hence it doesn't interest me going through it.. Please divide your program in functions where it gets easy to go through (I haven't seen the code)
  15. Harshad Italiya
    Moderator
    Please share the solution for the previous question. I have not got chance to spend time on that but now I think it is time to post the solution.
  16. Harshad Italiya
    Moderator
    @Vishal0203 will you please share your solution for that 0-1 swapping code.
  17. Vishal0203
    Computer Science
    I'll lay the method here,
    Keep 2 pointers, 1 at the start and 1 at the end.
    compare, swap and increment/decrement (increment 1st pointer, decrement 2nd pointer) the pointers accordingly.
    This continues until 1st and 2nd pointers meet
  18. durga
    durga Star
    Communications
    that looks like a variation of quick sort to me, being language specific(python) ,, swapping a within a list is possible, that would need the str to be converted to a list though, I still don't know if the same string can be skimmed that way and be swapped, other python-enthusiasts might chip in.
  19. Vishal0203
    Computer Science
    According to me python makes life easy,
    And so coding these small problems in python doesn't improve thinking skills
  20. durga
    durga Star
    Communications
    I would disagree. Python has many inbuilt functions which makes life easy, but that does-not in anyway deter you from full-filling the requirement of your project. It helps in abstracting all complexities of a language and thus aiding in the user to focus on real problem and not language nauseas.
    for example - python network programming gives you the flexibility to code at a higher application layer or as low as socket layer, in sense it gives more choice of usage. Anyways, each to their own.
Share This Page
