Static IP address
i have a wireless hotspot that whenever i connect to it it keep assigning different ip addresses each time am connected. do anyone have idea on how to use a static ip address on this network, instead of d different ip addresses it keep giving out. thank you......
Kaustubh KatdareRouter specific configuration will vary. Have you tried setting up your router in bridge mode? That should work, I guess.
Anoop KumarRight click on wifi --> properties -->General --> Internet Protocol(TCP/IP).
Is it set as "Obtain an IP Address Automatically".
open command prompt.
run ipconfig /all
set the IP address and DNS servers as given.
From IP address XXX.XXX.XXX.ZZZ , set any of your ZZZ high like 50+ otherwise if lots of devices connected to your router and after that you will connect to it you may face IP address conflict.
Hope you are looking for this only😀 -
durga chcan I know your need for static IP? are you hosting any servers ? or you are looking for a static Ip within your LAN?
da_jokerlooking for a static ip from a wireless network hosted by someone else...👍
KenJacksonAre you trying to access your PC from the outside world? Is that why you need to know the address?
I'm not sure what you're doing, so I don't know if it's relevant, but this URL returns your external IP address, and no extra text or formating: #-Link-Snipped-#
If you are running Linux (you didn't say which OS you're using) and you have write access to any website, you can create a script and run it often with cron to copy your IP address to a small text file on your site, something like this:#/bin/sh curl -s https://queryip.net/ip/ | ssh mysite.example.com 'cat > public_html/ip.txt'
Then, from anywhere in the world, you can get your home IP address like this:
IP="$(curl -s https://mysite.example.com/ip.txt)"
Alternately, you can use your home's URL. Most ISPs assign boring URLs to each and every IP address they have. You can get it almost the same way: #-Link-Snipped-# -
vishakkvyou need to configure ip reservation in wifi router for your device to get static ip
da_jokerthanks pals....i ave finally solve d issue.....
How to install windows xp on core i 5 processor laptop.
hi all... i am new in fuzzy logic field. can anyone tell me how to write fuzzy rules and membership functions in matlab......
Thanks in advance
Everest may be the tallest. However it is not the deadliest. It comes a low sixth in this category. It is interesting that four of those above Everest are in...
Two great civil engineering infrastructures celebrate anniversaries.
https://www.wired.com/thisdayintech/...+wired/index+(Wired:+Index+3+(Top+Stories+2))
https://www.bbc.co.uk/news/uk-england-birmingham-18094742
wel guys, i hv jst completed my 10+2, with not very satisfactory marxs, but fair enough to be eligible for b.tech. i paid no attention to studies in 11 and...
