SQL query on emp table to display the employee name, his salary, sum of his department salary
Write a SQL query on emp table to display the employee name, his salary, sum of his department salary and second highest salary of his department in different columns. This must be done for all the records in emp table. Any help??
[Prototype]Considering you're using MySQL,
SELECT * FROM `emp`
Are you trying to query from php and wants to display the results on the webpage? -
Neeraj Sharma
I am doing it on sqldeveloper. And I am not a noob that I dont know the query that you have given me. Please read my question again and then answer[Prototype]Considering you're using MySQL,
SELECT * FROM `emp`
Prashanth_p@cchiselect empname sal sum(sal) from emp group by deptno;
select sal from emp e where sal <
(select max(sal) from emp ea where ea.deptno = e.deptno) order by sal;
I am not sure of the above. It has been more that two years, me writing a SQL Query. Hope it might help you in arriving at the solution. -
Anoop Kumar
select e.emp_name, e.Emp_sal, (select sum(e1.emp_sal) from emp_tab e1 where e.dept_id=e1.Dept_id group by e.Dept_id) as Salary_Sum, (Select emp_sal from emp_tab e2 where rownum=2 and e2.dept_id=e.dept_it order by e2.emp_salary desc ) as Sec_High_salary from emp_tab e where e.emp_ID='XXXXX'
Prashanth_p@cchi
I think this should work... Nice!ianoopselect e.emp_name, e.Emp_sal, (select sum(e1.emp_sal) from emp_tab e1 where e.dept_id=e1.Dept_id group by e.Dept_id) as Salary_Sum, (Select emp_sal from emp_tab e2 where rownum=2 and e2.dept_id=e.dept_it order by e2.emp_salary desc ) as Sec_High_salary from emp_tab e where e.emp_ID='XXXXX'
Can anybody suggest any opensource IDE for running Django application??
Types of gas turbines and thier
1) Pressure Ratio
2) Air fuel ratio
3) Maximum Temperature in plant
4) Thermal Efficiency
https://www.instructables.com/id/EDC-The-pocket-knife/?ALLSTEPS
am misgana daniel froom Ethiopia and am very happy that i joind crazy engineers.
what are languages or courses to be done for placements...??
