Signal Transmission
i'm an ECE 2nd yr student
pls help me out with this problem
it will totally decide the grade of my 5 credit course
so pls help me out
You have 10 telephone signals which you have to transmit over a distance of 100 km. You have a cable through which you can transmit signals in the band from 1MHz to 1.5MHz with a loss of 1 dB/km. Any signal which falls below 1 mw is lost. Design a system for achieving this. Give a block diagram of the system, showing all the major units required. Determine the power levels and frequencies,
Discus the parameters which influence your choice of the various blocks and parameters.
Draw the waveforms and spectra at different parts of the system. Give expressions for these as also the values.
i would be really thankful to u ppl
pls reply : #-Link-Snipped-#
so pls help me out
Kaustubh KatdareDhruv, would you mind posting what you have done so far about this? We aren't here to provide ready-made solutions, you know 😀
Ashraf HZWell, I guess you start of with modulating the signal (PCM), add repeaters/amplifiers, etc.
reachrkataOne of the many ways that I can think of -
1) As suggested, use 8-bit PCM at 8kHz sampling (data rate is 64kbps). It is good enough for voice.
2) FM modulate all 10 PCM signals with 10 different carriers equally spaced in the 500KHz band. This is FDM transmission.
3) The advantage I see with FM is that signal level is not a very important criterion. As long as the frequency deviation is there you can still retrieve digital data. Nevertheless I feel repeaters would be required because 100dB looks like a big loss. You may also decide the need for repeaters based on the demodulator sensitivity.
Note these points -
I view this problem in a way that it is not important to find a solution (in this case many are possible). I think the aim here is to test your understanding of various transmission techniques, based on which you need to design a simple system, with as little components as possible and with as low power consumption as possible. I am not sure if you need to consider the cost aspect here, but I feel you can leave it.
So before you jump into a solution, try to spend some time on vaguely designing using other techniques (some 3-4 others you know) that you have learnt and try to choose the simplest and most effective one.
So the above mentioned solution may not be the best. So think in similar lines about other possibilities.
All the best.
Karthik
Ashraf HZ^ adding to reachrkata's point for a simple system, at least you dont have to worry about drawing complicated waveforms 😉
vissin1 dB per km is a huge loss. Considering that every 3dB loss accounts for power dropping to half it's initial value. 100 km leads to halving of power 33 times and the final power limit has to at least 1 mW! Taking a margin of 1.5 the initial signal strength therefore has to be at least (1.5 * 2^(33-1)) = 6.5MW approx.
That's awesome... or am I going terribly wrong somewhere?
Well, no matter what be the modulation technique adopted this high loss won't work. Repeaters have to be used, no doubt.
Well Dhruv. Read Kennedy. You don't have to be lazy. This sounds like a very complicated problem but there are many ways you can answer it in simple ways. Just get your basics right. There is no right or wrong answer to this problem as I understand it. It's just for academic purpose and is intended only to test your grasp of the subject. And here I see, my view coincide with that of Karthik. I second him.
Hi,
I'd like to visualize magnetic fields between magnets and charges. Fieldlines/streamlines would be ideal but e.g. vector arrows would do too.
Although a 3D model would be perfect, any...
[FONT='Arial','sans-serif']The Dearest [/FONT]
I have done engineering in SOFTWARE and now doing masters in COMMOUNICATION SYSTEMS AND NETWORKS. I need [/FONT][FONT='Arial','sans-serif']VOIP Applications basic architecture[/FONT][FONT='Arial','sans-serif'] project developed in any language...
(crazy)Ladies and gentlemen, presenting one of the craziest engineer alive:
Engineering Trade: Computer Engineering
Occupation: I do what my mother calls a side business. I'm a student,...
hii i have finished my 2nd year could anyone help me getting the list of companies that offers inplant trainings
anybody can upload plating process & screen printing process books pls
