Restrained retaining wall design
Hello,
I'm working on the design of a retaining wall, on which a steel hall will be mounted.
The retaining wall is not beneath the whole perimeter of the building, but only for part of the columns, as the terrain is inclined at a certain place.
As in my country's code is not clarified the situation with a hall, building, etc. above a retaining wall and I'm not yet experienced with this, I really hope I'll find some help here.
What I do now is to make calculations of the wall for 2 stages:
1) stage 1 - only the wall and the backfill - before installation of the slab and the hall - here everything is clear for me - I'm making the stability checks for sliding and overturning of the wall, check for the soil stresses and calculating the necessary reinforcement of the wall;
2) stage 2 - installing the slab and the mounting the hall (it will be pinned to the foundation). So for this stage the main question is should I check the wall for sliding and overturning as it is already restrained by the slab? Can I assume that the horizontal force from the hall goes directly in the slab? Than for calculation of the soil stresses I should take only the vertical loads. And what about the at rest load from the backfill - I suppose this horizontal loading can not goes also in the slab, can it?
I hope I explained it well.
Thanks a lot for all the replies in advance! I really have not any info in our code here..
See fast sketch here and in attachment:
Regards
Regards
I just wanted to know the difference between %u and %#u .....
Food & Bev Tech unveils ; plea to create Brand India & up food exports
https://www.fnbnews.com/article/detnew.asp?articleid=35972§ionid=1
Govt plans smaller clusters for food processing industry
https://www.business-standard.com/co...-food-processing-industry-114081100312_1.html
Indian Food Industry
https://www.ibef.org/industry/indian-food-industry.aspx
I just wanted to know how actually the expression which has many conditional operators in it is executed..
e.g System.out.println(8>2?7<3?6>3?5:3:9:1);
I just wanted to know that here I have 2...
I just wanted to ask that is the runnable interface is implemented just so that the class can realise the concept of multiple inheritance ,because if our class extends thread...
Descriptions are superfluous:
https://www.ba-bamail.com/Content.as...7nDOhAuOgGVeVroA7UqfrRJUc9NNRxaPrGJsT0=&d=294
