Rate Of Heat Transfer Problem
2kg of Water at 1 atm boils in 30 minutes. Find the rate of heat transfer to the water.
The answer should be -(2kg)*334.5(KJ/Kg)/(30*60s)=0.3716KW
Is the solution correct? The given options are not having my answer
a. 2.51KW b.2.32KW c.2.97KW d.0.47KW e.3.12KW
Krzysztof PelcAnswer is d. 0.47 kW
because:
Heat of vaporization is calculated from a temperature of 100 degrees at a 1 atm and yet you have warmed these 2 kg of water at 100 degrees .... and hence the difference -
ISHAN TOPREhfg for water at 100 deg= nearly (2675-491.17)=2183.83
2*2183.83/(30*60)=2.42
No option. How come you are getting 0.47? -
ISHAN TOPRE334.5 KJ/Kg is latent heat of ice and not steam.
Krzysztof PelcHeat of vaporization is the difference enthalpy between the points on boundary curves
h1 = 419.71 kJ / kg, h2 = 2675.72 kJ / kg
h2-h1= 2256 kJ/kg !!!!!!!!!!!!!!!!!
Q=m*dh/3600 /heat related to hours
Q=2*2256/(30*60)=2,51 kW
Answer a. is correct - first time i go after you suggest 😀)
NEST Learning Thermostat home automation system finds itself currently housed in 120 countries across the world, even though its availability was restricted to US and Canada thus far, with UK...
hi,
i got 24.58 marks in gate(2014) under (OBC) and my gate score is 339
so with this any possiability to do M-tech if it possiable which kind of colleges...
The Chinese multinational company - Lenovo has been under the spotlight ever since they bought Motorola from Google for $2.91 billion. Lenovo already has a line-up of A, K, S,...
MathHarbor is a cloud based platform that leverages the power of cloud computing to save the pain of numerical computing needs. Currently, MathHarbor supports the Octave, Scilab, R and Sage...
Robots working elbow-to-elbow with people at work isn't a surprising picture anymore and now researchers are ready for taking the next big step. Industrial designers are changing the way they...
