Questions related to formatting
I have a question in my mind from a long days. So today i am going to ask this.
When we makes a partition and at first if we loads XP in 1st partition and then again if we loads suppose Win 7 in another partition.
Then after somedays if I wan't to remove Win 7 with any other OS, but not to remove XP from is partition.
So if I formats that Win 7 partition with any other OS by keeping the Win XP safe, I found that after formatting Win 7 partition with other OS my XP is also unavailable and only that particular OS is loaded .
So i wan't to know what's the reason of this ?
Is XP performs as Masterboot ?
  • Leo
    Leo
    Hi Rishi the above problem occurs due to boot loader priority.
    Previous versions of Windows(Before vista) use NTLDR which acts as boot loader for XP too, when MS launched Vista he replaced NTLDR with more powerful boot loader GRLDR. When newer loader is launched the new boot loader gets priority in boot, so the new boot loader stores information about the previous boot loader and replaces it in MBR.
    So here is priority of boot loader which is standard even today,
    1. GRUB (Grand Unified Boot) Linux and Unix Boot Loader
    2. LILO (Linux Loader) Linux
    3. GRLDR (Windows Version of GRUB Loader) For Vista and above
    4. NTLDR (New Technology Loader) For XP and below
    So when you formatted Windows 7 the GRLDR information got lost and you are now not able to load Windows XP because NTLDR information was stored in GRLDR. To get rid of this problem try this.
    1. Boot your system with XP CD.
    2. Select repair system in command prompt mode
    3. Type FIXMBR .It will ask for confirmation, allow it.
    4. Then type FIXBOOT. It will again ask for confirmation, allow it.
    5. Then try booting normally.
    It should work fine, if not, try again, even not then just reverse order of commands type first FIXBOOT then FIXMBR. Reply that worked for you or not.
    Happy Computing.
  • optimystix
    optimystix
    tell me if I am correct. From what I understand, you mean to say that you have installed XP on 1st partition and then WIN 7 on another one. So now while booting up the computer, you can see two options- WIN 7 and WIN XP. Now sometime later you wanted to remove WIN 7 keeping WIN XP intact. But after removal of WIN XP you see that XP becomes unavailable to you.
    you must have removed WIN7 by formatting/deleting the partition with a WINDOWS disc right?
    Earlier when you installed WIN 7, it took over the boot controls from Xp and later when you removed WIN 7, the boot entries containing boot info of WIN 7 n XP got removed/deleted. Just now your XP too is no longer available. To re-enable it, you need to restore the boot record in XP using various software available.
    Tip: In future, if you ever need to delete WIN 7 , first restore the boot records in WIN XP and then delete the partition containing 7. It will be smooth sailing for you. ๐Ÿ˜€
    EDIT: you will find LEO's explanation much better than mine ๐Ÿ˜›
    note that, fixboot and fixmbr is the easiest solution available but causes a problem in windows partition.It is not the most efficient way to do it and thus avoid it. Use various software boot discs available to perform the operation or use easybcd to correct it. The best option is to set WIN XP as default in the boot loader and then delete the WIN 7 partition.
  • rishi0922
    rishi0922
    Thanks to Leo and Optimystix for such a helpful solution.....
  • ramana_slv
    ramana_slv
    Hai friends I have one doubt. When ever we install dual operating system first install one OS then remaing unpartitation for another OS ...
    This is one way. Another way is install entire OS in the hard disk then second OS install particular harddrive(D,E,F...) like in this which one is best and why? please tell me ...............
  • rishi0922
    rishi0922
    @ramana:
    If you can make partition of hard disk then all the partition that you have made becomes the local disk of your hard disk. So you can install your OS in any of the local disk which have sufficient memory.
    So both the way is similar and you can use any of the way you wan't .......
  • anandkumarjha
    anandkumarjha
    I have one more doubt that according to optimistix if we install window 7 as a second os keeping XP for the first partition then while installing window 7 it takes boot control from window XP.Now insteed of removing window 7 if we remove XP ,will window 7 get removed as window xp does not have boot control now?
  • rishi0922
    rishi0922
    @anand:
    Win 7 will not be removed but it's loader will not load it now ....
  • harihar rautaray
    harihar rautaray
    Friends when I login it asks to choose 2 OS of same "windows 2000 proffessional"
    If i choose 2nd it gives a message "Not able to find"
    and if I choose 1st it boots normally
    it gives 30 sec to choose
    can any one tell me why 2 OS is visible
    thanks in advance
  • Leo
    Leo
    Hi Harihar you have installed same OS twice on same system hence this problem occured. Your HDD have two same boot loader i.e NTLDR and NTLDR for the OS that boots has still information about NTLDR for OS in option two. If you have both OS installed and still error occurs, you can fix problem by bootable CD. If you don't have any OS for second option then being honest, i never encountered that kind of problem but i don't that might not be that big soup to fix.
    Happy Computing.
  • rishi0922
    rishi0922
    Can we install all versions of Linux inside the windows ?
  • Leo
    Leo
    rishi0922
    off course.
Guys, I dont know whether this information is posted earlier or not. Searched but didnt get though. Here is the link after going through it.. I thought its a very...
aha! one of the person's whom I assocaite when someone says 'CE' ๐Ÿ˜ I hope I am not wrong, but today is his BIRTHDAY :myparty:HAPPY BIRTHDAY ASH:myparty: ๐ŸŽ‰ PS: did...
What is the difference between Multi-programming and Multi-tasking? Please illustrate with an example.
CEans, You asked for it and we have it ready for you. You can now 'Like' the discussions on CE and share it with your friends on Facebook ๐Ÿ˜ with...
Facebook Like button has been introduced on CE for all the threads. If you like any discussion on CE, be sure to click 'Like' button and help us spread the...
