Project idea for underground water level detector
I am having a look at the topic underground water level detector for my project... I was thinking based on the idea of passing some waves and getting it reflected back and measuring the distance with speed and time but this will not work as water does not reflect back any wave..... After browsing for hours found about geoelectric survery need more info about this and its implementation...........
Harshad Italiya
Right now government using Inset for such water sensing but its use for civilian is not allowed. but using some high strenght wave we can check it.subinrobinI am having a look at the topic underground water level detector for my project... I was thinking based on the idea of passing some waves and getting it reflected back and measuring the distance with speed and time but this will not work as water does not reflect back any wave..... After browsing for hours found about geoelectric survery need more info about this and its implementation........... -
subinrobin
could you tell more about InsetgodfatherRight now government using Inset for such water sensing but its use for civilian is not allowed. but using some high strenght wave we can check it. -
Harshad Italiya
en.m.wikipedia.org/wiki/Indian_National_Satellite_Systemsubinrobincould you tell more about Inset -
subinrobin
can i do a project on this topicgodfatheren.m.wikipedia.org/wiki/Indian_National_Satellite_System -
Ramani AswathThe problem is water is not present as a sheet of water underground but as a filler for the pores of the soil deep down. There is a general ground water level and even a flow. However, no waves can detect it because of interference by the soil itself. Geologists do use electric resistance measurements for studying underground mineral formations. They also use shock wave propagation. by setting off small explosions and monitoring reflected waves. As far as I know this is not suited for water divination.
GRACE (the Gravity Recovery and Climate Experiment) using satellites designed to detect changes in gravity can detect ground water level differences as small as 1 cm but over very large areas.
This is not a single person project. Needs too much equipment, people, budget and time.
If you can tell us your other areas of interest, probably some one may come up with some ideas.
I am reminded of Balachandar's movie, 'Thanneer, Thanneer':
subinrobin
I am interested in socio economic projects.... Some ideas for thatbioramaniThe problem is water is not present as a sheet of water underground but as a filler for the pores of the soil deep down. There is a general ground water level and even a flow. However, no waves can detect it because of interference by the soil itself. Geologists do use electric resistance measurements for studying underground mineral formations. They also use shock wave propagation. by setting off small explosions and monitoring reflected waves. As far as I know this is not suited for water divination.
Ramani AswathHave you heard of Engineers Withoout Borders?
Join them and find out how you can contribute:
Engineers Without Borders, India
What other online activities these days should be taxed? Sound out in the comments! (and I might just create a Part 2 of this if I get too lazy!)
And...
Have you seen popular Hollywood movie: Surrogates. If yes, you must be wondering that Bruce Willis was struggling in a world dominated by realistic robots that were controlled by humans...
Have completed my n+ and ccna training,now preparing for cert.But still in a dilemma, are these certs really helpful spending nearly 20k bucks on them?
I have been looking for...
Hai this is govind from vizag ,studying 4th mechanical .I am here to know some important topics about future projects ,i hope this site helps me for some extent.
