programming problem in C++
I was trying to solve this problem but got stuck.the problem goes like
I have a string of 0's and ones which is to be inputted by the user ..
may be something like "000110010"..The solution is a string in which I get 0's on one side and 1's on other side( like compaction where 0 represents used memory and 1 represents free memory)..+ the total distance (in terms of shifts) ..
For the string: 000110010..the output would be 000000111. and the diatance 1's or 0's have to be moved to achieve the output!
Can anyone help ????
pooja sehgalplz mention about d distance moved
we have to specify the distance moved by each 1 or 0 ????
or the total distance covrd by all 1's & 0's?? -
ankur8819It is the total distance moved by all zero's or one's!
pradeep_agrawalBelow is a sample code for above problem statement.
#include "stdio.h" #include "string.h" #define MAX_STRING_LEN 100 int main() { char str[MAX_STRING_LEN + 1] = {0}; int strl = 0; int move_count = 0; int move_pos = 0; int i = 0; scanf("%s", str); strl = strlen(str); if(strl < 1) { printf("Empty string\n"); return 0; } for(i = 0; i < strl; i++) { if((str[i] != '0') && (str[i] != '1')) { printf("Invalid character in string\n"); return 0; } } for(i = strl -1, move_pos = strl - 1; i >= 0; i--) { if(str[i] == '1') { str[i] = '0'; str[move_pos] = '1'; move_count += move_pos - i; move_pos--; } } printf("Result string: %s\n", str); printf("Total movement: %d\n", move_count); return 0; }
Compile the file with above code and run as:
a.exe < input.txt > output.txt [on windows]
a.out < input.txt > output.txt [on linux]
Here,
a.exe or a.out are the executables generated after compilation
input.txt is the file containing input string
output.txt is the output file containing result
-Pradeep
what is the principal for vacuume pump?
in my project i require bcd at port 0 and 3 of microcontroller 89s52 since there are three 7447 connected
(i.e p0.0-p0.3 to 7447(1) lsb,
p0.4-p0.7 to7447(1),
p3.0-p3.3 to7447(3)msb)
which...
Hello i want the use of delegates especially where exactly they use delegates and how .
i hope it is ok for this forum. may i invite all capricorns to join - it is a forum site for all capricorns. thanks.
i am a crazy CSE student n im in 3rd semester..........๐;-)
