Problems on aerodynamics
A hypersonic experimental aircraft is flying in the lower stratosphere at an altitude of 20 km, at a ground speed of 177m/s.
a)the atmospheric pressure and temperature experienced by the aircraft at 20 km altitude, assuming an isothermal variation in temperature in the stratosphere,calculate
b)the Mach number at which the aircraft is flying.
c)the Mach number behind the shock wave located just ahead of the aircraft nose.
d)the temperature and pressure experienced by the tip of the aircraft nose.
zahidfcukcan anyone tell me, where can I get some solved problem in aerodynamics??
roopits4mehiiii,
refer these books once it might be helpful for u.
Introduction to flight - Anderson
Fundamentals of Aerodynamics - Anderson
Aerodynamics for Engineering Students - Houghton and Carpenter/Caruthers
Aerodynamics - Clancy
Modern Compressible flow - Anderson
Gas dynamics - Rathakrishnan
Viscous flow - F M white
Skype users - be happy. Skype 5.5 for Windows is now available for download. Skype 5.5 for Windows comes with deeper integration with Facebook. You don't have to leave Skype...
CircitBee comes to your rescue when you want to share your electronic circuit designs with fellow engineers. CircuitBee takes your schematic project files, converts them into its own internal format...
i making my own robotic arm parts but the problem is which is best choice to make it???acylic or hardwood?? shud i use cnc machine or leth ?? i will...
Hi everybody
I found one good resource of receiving Online Certification like CCNA / CCNP / ORACLE OCP / SOLARIS - JAVA / ITIL / HP / SYMENTEC NETBACKUP etc...
hai. Iam anish
