Pin Insertion Mechanism - Thoughts
So the thing is, my team is working on automation project. It consists of two stations, at the first station a Pin of 4 mm diameter will be pressed into a similar dimension hole. and at the second date will be punched on it.
We are using a hydro pneumatic cylinder for the desired stroke at first station. The challenge here is designing a mechanism or fixture which will hold the pin and will keep it in straight position so that pin wont get damaged during insertion stroke.
Your ideas and thoughts are most welcome!
FlyingMachine
4 mm pin shall have a 2mm pilot shank with suitable length, 2 mm to 4 mm should be a smooth taper. there shall be a undercut at 4mm start point.Kedar MalwadkarSo the thing is, my team is working on automation project. It consists of two stations, at the first station a Pin of 4 mm diameter will be pressed into a similar dimension hole. and at the second date will be punched on it.
Installation steps:
1.insert the 2mm pilot
2.punch from 4mm side till it flush
3.snap off the 2mm pilot @ the undercut
Abhinav Asthana grew up in small towns across Uttar Pradesh, thanks to his civil engineer father who worked at the Public Works Department in a job that demanded frequent transfers....
Researchers at Tufts University have created a material derived from silk-protein that can be pre-programmed to serve multiple functionalities. These 3-dimensional materials can be programmed with biological, chemical and optical...
The pangs of a long-distanced relationship can now be smoothed, as you get to have kisses of your loved one to warm your heart and keep you company. The new...
Do you have a lot of work to manage? If you hail from a business community, maintain a strict schedule, organize frequent conference calls or simply geeky enough to digitize...
We've been focusing on improving the Events app so that it's actually very useful for all our fellow engineers. Here are the features that will be introduced over the next...
