mild steel casting
why mild steel have higher cooling rate than cast iron after melting.
N.Gowtham RajTry referring CCT curve from any material engineering book...
wu hanHey,
Stainless steels are distinguished from other steels by a minimum chromium content of 10.5%, which makes them more resistant to
corrosive aqueous environments and to oxidation. Although there are exceptions,stainless steel castings are classified as "corrosion resistant" when used in aqueous environments and vapors below 1200°F (650°C)and "heat resistant" when used above this
temperature.To know more about go to Search Results For Products By Name: [ mild steel casting ]
A who was born in country B, established the calendar C, which is many years ahead of the calendar D (also known as E), introduced by F.
C is the...
hey engizes can anyone give me any idea for how to prepare for the cdac xam so as to get admission for the course of vlsi and embedded
i proude to be a mechanical engineer because it is the world oldest branch from the centuries of ramayana . THE total defence power of an country is fully dependent...
JVC's GS-TD1 3D camcorder now available for $1,700 -- Engadget
JVC promised back at CES that its new consumer-grade GS-TD1 3D camcorder would be available in March and, well, it's...
Transformers: Dark of the Moon (2011) - IMDb
