Mean Shift Algorithm
Hi
m a newbie so please correct me if i am posting this in the wrong section.
I wanted to discuss how to apply the mean shift algorithm in Image Processing for tracking objects. More specifically, it wud b gr8 if u cud explain me the Continuously Adaptive Mean SHIFT (CAMSHIFT) algo implementation.
Thanks
Thanks
serene.kI have a problem with the implementation of the mean shift tracking algorithm.The weighted mean is moving in a different direction when I implemented the algo given in most papers i.e the weights calculated as square root of the ratio of the frequency of the particular bin color at a pixel in current frame to the frequency of the same bin color in the next frame.Intuitively it has to move in the direction of the moving object,but it is moving in an opposite direction..the calculated weights are actually moving the bounding box in the upward direction.Can anyone help me with it?
serene.kwhat exactly should be the weights for the pixels?
Who said engineering can't be cool?
Animated music video by Rajeev Bajaj
IEEE Spectrum: Video Viewer
Great stuff! Alright, maybe it might be aimed more towards those in computing.. but...
latest computer seminar topics(details) software+hardware😔
[FONT=宋]router:
1\ctrl+break login rommon 1>
2\rommon 1>confreg 0×2142
3\rommon 1>reset
4\router>en
5\router#copy start run
6\router#conf t
7\router(config)#enable sec c1
8\router(config#config-register 0×2102
9\router#copy run start
10\router#reload
switch:
1\ctrl+break login switch:
2\switch:flash_init...
how do we give a digital 1 or 0 to a wire..(does giving a wire 5v makes it digitally 1 and giving 0v makes it digitally 0??)
suppose i have...
Why do we use multiples of11 as voltage in transmission lines😕😕
