LM555 output frequency drops when supply voltage from the regulator
Hi,
I'm using a LM555 timer to produce a frequency of 240KHZ & 50% duty cycle.
The circuit i'm using is Astable.
RA is 82ohm
RB is 200ohm
C is 0.01uF
RLs nothing
I built up this circuit and got nearly 240K frequency and 44% duty cycle
But when use a normal LM340T5 to produce a 5V to the LM555 timer...
The frequency immediately drop to 190KHZ
This cause my 3rd IC almost burn T^T
anyone can guide me to the solution?
Thanks
Best Regards
Wan Xi
The LM555 Circuit which provide 240KHZ & 50% Duty Cycle:
The regulator Circuit:
RA is 82ohm
RB is 200ohm
C is 0.01uF
RLs nothing
Thanks
Best Regards
Wan Xi
sauravgoswamihey check your capacitor value,secondly somewere loading is goin on...
ahmed_hassan133first,be sure that your de voltage is 5v purly after loading,and also check this link for mor information
www.national.com/ds/LM/LM555.pdf
hi CEan's..
please give me breief explanation abt importance and duties of Soft ware engineer
Hello,
I m an owner of a small business and like to make my presence felt in internet. Can somebody suggest how to go about?
Thanks in advance.
3M innovation leads to introduction of its safest auto-darkening welding shield to date
There are many different welders, from the full-time professional to the occasional hobbyist. However, it does not...
Im doing a project to send gps data via gsm mobile phone.But i dont know how to interface a mobile with my PIC16F877A.I understand from my seniors that it would...
hi to all, ahm can you give me idea or info about pc base disco lights...
because were undergoing thesis and we need more info about disco lights, pc base...
