Lasers Might Be Used To Rid Of Space Debris Soon
With every satellite launch, we see an increase in debris orbiting around the earth. Itâs not just debris from the satellite launches but also defunct satellites, 500,000 of them are orbiting the earth creating a deadly threat for active orbiting vehicles. In the past, NASA has concocted Gecko Inspired Technology Could Become The Garbage Truck For Space Largest Solar Sail Ever To Be Launched by NASA in 2014 for tackling this nuisance but this time Japan's Riken research institute has thought of a new way that is not just utilitarian but also ultra-cool. A proposal has been submitted by scientists from RIKEN, University of California, IZEST EcolePolytechnique, University of Paris and University of Torino that talks about a laser mounted on the International Space Station that shall monitor and destroy space debris out of earthâs orbit. The system that will require no assistance from ground control consists of EUSOâs infrared telescope and a CAN laser.
EUSO
Extreme Universe Space Observatory or jem-euso.uchicago.edu developed by Japan's Riken research institute has a telescope that is currently being used to detect ultraviolet light emitted produced by ultra-high-energy cosmic rays entering the Earth's atmosphere at night. The Japanese researchers believe that since this system has wide field of view and powerful optics it can be modified to detect high-velocity debris fragments at twilight. The second part of the proposed system requires a fibre optic CAN laser that is found in particle accelerators. Once the telescope identifies the debris, even the ones with diameters of 1cm, it can fire powerful laser pulses that cause a phenomenon called as plasma ablation that will heat the object and turn it into plasma. This shall push the disintegrated debris into earthâs atmosphere that shall obliterate it instantly.
In the proposal that has been published in the #-Link-Snipped-# journal states that the implementation shall take place in two phases. The first phase shall be a proof-of-concept test on the International Space Station with a 20cm version of the EUSO telescope and a laser with 100 fibres. If that goes according to plan a full scale version shall be installed on the ISS that shall consist of a three-meter EUSO telescope and a laser with 10,000 fibres that will be capable of obliterating debris in a range of 100 kilometres. The researchers have also chalked out an additional plan which shall consist of a free flying satellite in the polar orbit that will have a range of 800 kilometres.
For more information on this development, you can read the journal link mentioned in the above paragraph or its coverage on #-Link-Snipped-# and #-Link-Snipped-#.
EUSO
Rajni JainWith the growing number of space projects, cleaning up the space garbage / debris is the need of the hour. New research from Japan's Riken research institute is ultra-cool.. probably a very much like a sci-fiction movie.
Kudos to all, who are thinking in this direction and making it happen.
Whenever we talked about poverty the thing that strikes in ours mind is poorness, a mother with hungry three or four children, slum areas etc. Of course this poverty is...
The Central Japan Railway Company has informed the public that its magnetic levitation bullet train has broken the world record for the fastest train. The prototype train with 29 technicians...
Google's Project Loon, as you may already know, is an ambitious project to deliver the Internet around the world using tens of thousands of balloons floating in the sky. According...
Hi CEians..!!
What type of questions can i expect in IBM technical associate's online assessment test??
best way of selecting options
