Joining process of mild steel and aluminium?
Can anybody suggest me the joining process of mild steel and aluminium.If this is possible,please let me know the specification of arc welding electrode or gas welding flux
joshua1980Bimetalic Transition inserts can be used . The arc welding of these steel aluminum transition inserts can be performed by the normal arc welding methods s. One side of the insert is welded steel-to-steel and the other aluminum-to-aluminum.
Viswanathan ChockalingamWelding of Aluminium by Arc welding is a great problem due to the formation of Alumina.Alumina being more in weight than Aluminium,will cause slag inclusions.
Al-Al welds can be made by using TIG,MIG,Friction welding etc.,
When it comes to Dissimilar metal welds, TIG and MIG can never be used due to unavailability of Filler.(However for small thickness TIG can be used without Filler).
Friction Stir Welding is a latest process which is apt for this situation.It can be done with Vertical Milling Machine.You need a tool alone. FSW setup is avilable in many educational and research institutes.
Also Al-Steel joints can be made by Bimetallic strip,however it is a third member and adds to the weight of the weld and the strength is low.Yet it is apt if your samples are less in number.Bimetallic strips are available and you can buy and easily weld,Al-Al and Steel-Steel. -
abhijeet chandak
Metal arc welding, gas tungsten arc welding, gas metal arc welding, and submerged arc welding can be used to join dissimilar metals but the high energy inputs of these welding techniques may result in material metallurgical mismatch. Therefore advanced welding techniques like laser welding, ultrasonic welding, friction spot welding, and friction stir welding processes are more feasible.
Ramani Aswath
Reliance Industries owned smartphone brand LYF has launched another Voice Over LTE (VoLTE) handset in the Indian market called the LYF Wind 5. As the name suggests the Wind 5...
Getting a 4G enabled smartphone in India has become cheaper than ever with the launch of the Intex Cloud Glory 4G. The smartphone is also one of the cheapest ones...
Yesterday, Opera Software ASA announced a stable release version 38.0.2220.29 for its well known product- the Opera Browser, and they call it Opera 38. So what? Web browsers do get...
Back in 2014, online video streaming giant YouTube did something revolutionary to help it gain more ground in India. YouTube launched the offline mode on its app which allowed users...
While we had a look at the entry level smartphones launches today with the Intex Cloud Glory 4G and LYF Wind 5 let us take a look at the new...
