JDBC Connection with DB2
Hi
i am a CSE student. i have completed core java, i am not able to graps a vast knowledge on JDBC connection.
so kindly give some notes, tips & tricks on JDBC which help me to developing some large project.
thank you.
thank you.
Elisa
Following might helpswastiHi
thank you.
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver"); return DriverManager.getConnection("jdbc:odbc:" + databaseName, userId, password);
dhwanitsshah
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver"); Connection con=DriverManager.getConnection("jdbc:odbc:DSNname"); Statement st = con.createStatement(); e.g.->String sql="Select * from databasename"; St.executeUpdate(sql);
zeem_710😎 Here is the code to connect JAVA and DB2
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver"); Connection con=DriverManager.getConnection("jdbc.odbc.DSN"); If your has a username and password, then provide the following: DriverManager.getConnection("jdbc:odbc:DSN","user","password");
Add the path of IBM>db2>SQLLIB>BIN to the "path" environment variable(if u r working with Windows).
or, extract the "com" package from the src.zip file in bin folder of IBM DB2 to the folder where u have stored ur Java class file. -
mlumantahi guys im new here., how are you?
hi..i want to know about torrents...what are these.....
how to download them...and every possible infomation possible..
actually i visite da website mininova.org..i was trying to download some torrent ..but whenever...
dear friends i m new member looking for ur fast help
i need information about the reaction of chlorine and methane in wastewater treatment
hi everyone...
i hv recntly joined d gang of "d crazy engg".
wl,can anybody of u can help me wth sum easiest code for the following
conversions in STACK.
1....
Which is the good book for electrical science and engineering chemistry for b tech 1st and 2nd semester
hello friends,
could any one of you tell me how to protect a folder/file using DOS ?
😁Thanks in advance for you answers.😁
