How web server knows that the requests is get or post ?
when browser send request to the server, how server come to know that requst is get or post?
  • [Prototype]
    [Prototype]
    Gives you the clue?
  • Manish Goyal
    Manish Goyal
    [Prototype]
    Gives you the clue?
    Hey what does this action attribute value indicate, I have never seen this before?
  • [Prototype]
    [Prototype]
    goyal420
    AFAIK, all forms that submits data has that attribute. It just specifies the location where the user data is to be sent for further processing. I took that snippet from CE itself.
    A simple example would be,
    This is send the data of login form to login.php.
    Is this what you're asking?
  • Manish Goyal
    Manish Goyal
    [Prototype]
    I know what does action attribute means, I want to know about this value
    1. inline-mod/post/switch
  • [Prototype]
    [Prototype]
    goyal420
    Took that from CE, actually from this same page itself. 😁
    Its certainly the url to some module specific to the CMS of this forum. Not a feature of html. Sorry, never thought it would create confusion like that. I now see where you're coming from.
  • Anand Tamariya
    Anand Tamariya
    pranav Goswami
    GET or POST is defined as part of HTTP request header. You should read about TCP/IP programming if you need more details.
i am in BE last year....pls give mi suggetions...about the computer security projects....
To disable the access to USB port, for pen drive: 1. Click Start, and then click Run. 2. In the Open box, type regedit, and then click OK. 3. Locate,...
I am doing speech -music discrimination using matlab as my main project. In that i am having rms module , zcr module and lpc module. For each individual signal i...
Hello , I m Arun ,a b.tech 2012 passout . i have been searching for job since since June 2012 in Delhi Ncr . I know Java,J2ee,Android,Php,Drupal,Joomla. I joined a...
I have following questions p=VI If a power generated from a gas turbine is 300 megawatt, then what is the value of V & I in this power, and what...
