How valve timing cams are manufactured ?
hi guys many previous post says about camless engine but i have a doubt how these ordinary valve timing cams are manufactured. ya we learned to draw cam profiles but how these are manufactured with respect to rotation of crank. mostly they both are connected by chain drive with 1:2 ratio speed. how these perfect lobes on cam are made for the valves. what if i want it at 1:1 ratio speed. pls reply.
tufelSir,
recently in an industrial interface i was able 2 see how the inlet & exhaust valve opens. the cam is connected with the follower. the same is connected to the push rod to the rocker arm to the spring when the camshaft rotates the arrangement compresses & expands the spring that makes the valve open at regular intervals -
gohmI'm assuming you are refering to roller cams and not flat-tappet or hydraulic lifter type? Lobe lift, pattern & seperation angle all determine cam performance. They are usually made of cast or billet steel. Flat appet lifters cannot be reused or removed, whereas roller cam ones can.
6nv6im sorry but what is cam engine? 😕
gohmCams operate the valves of an internal combustion enigine using lobs on a shaft power by a timing gear.
shiv200887But how cams are manufactured? which technique will they use to machine the cam with such a great accuracy?
gohmthey are normally cast or billet
Lately, I've been hearing that many companies have delayed the joining date for the engineers who graduated in 2008. Now, since the number of students who have offers but no...
I think it would be interesting to seek opinions from our fellow engineers about which job portal produces better results.
Once we get few names, we'll start a poll.
Source: IBM Research | Ponder This | December 2008 challenges
Consider a random walk on the 2-d integer lattice starting at (0,0). From a lattice point (i,j) the walk moves...
glad been here folks, a newbie computer engineer from the Philippines......
I wish all our fellow CEans a very
HaPpy & Prosperous New Year 2009​
May your life be filled with eternal joy. May your dreams come true. May you change...
