how to program CPLD
Hi all,
Could tell me how to program CPLD(cool Runner-II)?
Example:XC2C25
Thanks
balaseven
Example:XC2C25
Thanks
balaseven
Abhilash41Have u designed the logic and generated the programming file?
Assuming that u have :
get a JTAG programming cable.Connect your CPLD's JTAG signals and voltage reference to the semi-industry-standard 14-pin 2mm connector. Check the programming cable's data sheet for the connector pinout. Use the cable to connect your computer and your CPLD, and use Xilinx's iMPACT software (included with ISE) to download your programming file to the CPLD.
If u need help with the programming post a reply. -
Abhilash41Found this tutorial. might be helpful :
Hi,
I am building my first line following robot but I need help in sorting out alot of issues.
1) I don't know what my circuit should look like and...
What motor driver would you recommend for my line following robot. I am using geared motors...(if that is of any help!!!)..
Thank you.
hello everybody....................
hi..............
if ne1 can give guidelines for gettin placed in dis trade.,....dat ll b much helpful..................so plz...........give sm technical info required,,,,,,,,,,
Hello all,
I have just joined crazy engineers.
Guys can anybody tell me in any substation what are the factors or steps for selection of any equipment like Circuit Breaker,...
